Question about Corel Draw X6 Graphics Suite WINXP/VISTA/WIN7
Initializing the Setup - Please Wait
Setup stops after this message Initializing the Setup - Please Wait
  • Bremzy
    Bremzy Oct 09, 2014
    i have the same problem. any solution?
How long have i to wait until i am informed how to set up an ebay account please?
depending on your info and you have a valid email account setup and co,formed via the message in email box, should be straight away but your account will be limited until you have confirmed your back details. that takes 3 days depending on your account setup with your bank.
Jan 22, 2017 | eBay Computers & Internet
Dialta di2510 not initializing
Unplug it from the wall, wait a while and plug it back in. If still not booting, Probably needs to have the firmware reloaded,or all the dimms (memory chips) need to be reseated, or the main board has failed. If you are not a tech, probably should call one.
Sep 02, 2014 | Konica Minolta Dialta Di2010 2510 Toner 2...
Turn power off and on again appears on the screen
Turn the Power Off and On again error message is displayed when the Lens in the Camera is stuck is affected by a malfunction. Try turning off the power and on again. If the issue persists, try performing a power reset.
To power reset the Camera; turn off the Camera and remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the Camera to remain without power for 60 seconds.
Then, reinsert the battery and check if it helps.
You may also try INITIALIZING the Camera.
To Initialize the Camera, press the On-Screen key.
Touch MENU-->SETUP-->SETUP 2-->INITIALIZE-->OK. Initializing the Camera will change all the settings back to factory reset.
If the issue persists, service may be required.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
Is there a reset button on the 27 inch sharp aqua tv?
  • Press "Menu" on the TV's remote control and use the arrow keys to scroll to "Setup."
  • Scroll down to "Reset" and press "Enter" on the remote.
  • Select "Yes" using the arrow and "Enter" buttons at the "Return To The Factory Preset Values" message.
  • Select "Yes" using the arrow and "Enter" buttons at the "Now, TV Will Restart Automatically. OK?" message.
  • Wait while "Now Initializing..." appears on the screen. The TV will power down and turn back on when the reset is complete.
  • Read more: How to Reset a Sharp Aquos ' eHow.com http://www.ehow.com/how_7225301_reset-sharp-aquos.html#ixzz12i633RwM
    Oct 18, 2010 | Sharp Televison & Video
    Hello! My PC crashed once, and i can't reboot it. It aborts while " initializing usb.. " directly after starting. (Win7)
    if there are any external HDD attached unplug them before you boot.. try that first...if that doesn't work,..reboot..then press F12 or F2 ( you might have to tap-tap to get into settings ) to go into bios settings. disable boot from usb and make sure that the boot setup starts with the cd-rom first then the HDD 2nd and nothing 3rd.and if that fails... hopefully you made a back up/repair disc. use that...9/10 times it will fix what the problem is.
    Jan 26, 2010 | ASUS P5PL2 Motherboard
    Won't zoom :(
    Option 1:
    Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
    1. Please press the Menu button on the Camera.
    2. Then, select the SETUP menu and select the SETUP 1 option of the Camera.
    3. Then, select the Initialize option to OK.
    Option 2:
    If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
    If the issue still persists then Service may requires to resolve it.
    Aug 11, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
    The RCA Easy Rip Installer has detected that a critiical file is missing : Setup.XML
    If you are not prompted to install easyRip, you can find the installer on the device itself or download it at the URL listed below.
    If you are getting the message that a critical file is missing, download the latest installer at:
    http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2253
    Please clarify about the player stuck initializing. What model of player is it? Is the device itself stuck initializing or is a firmware update for your device (would be on your PC) stuck initializing?
    Jul 20, 2008 | Audio Players & Recorders
    Unable to install windows xp
    > Make sure that hard disk is detecting in C-mos setup.
    > If it detecting in C-mos setup than Make sure that all parttion will
    be in NTFS or FAT not Ext2 or Ext3
    > This problem is Directely Associated with your hard disk
    Dec 03, 2007 | Microsoft Windows XP Professional With...
    Software won't work with vista
    Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
    Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
    Corel Draw X6 Graphics Suite WINXP/VISTA/WIN7 Logo
    279 people viewed this question
    Top Corel Computers & Internet Experts
    photoshop serial
    Dan Shibata
    Dan Shibata
    Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
