Question about Apple 24" iMac Desktop
How to reformat iMac 24 computer
Unable to repair disk. says to reformat disk
Apple
good idea
first run disk utilities, then defrag disk, then connect ssd to computer via usb external drive, then clone disk or install disk into machine and then insert system disk and boot from system disk and hold down c key.
Mar 21, 2014 | Apple 24" iMac Desktop
UNABLE TO REFORMAT DISK
Do you have access to another computer to try reformatting the disk on? Or has your computer been 'acting up' lately? If so, the BSOD is probably just that & it's time to start looking for a new computer. I had this happen to me recently and took my computer in to a reputable repair store in my area that I had used before and they did manage to retrieve MOST of my stored pictures and media. But, I'm sorry to tell you, the computer never worked again. Good Luck!!!
Jan 29, 2012 | Computers & Internet
G5 stuck on white screen
Have you got the Snow Leopard boot disc that came with your machine?
Pop it in the iMac, restart the computer with the "C" key held down. That will boot the imac to the DISC. Once there go to the top menu and run a Disk Utility Repair on the hard drive.
Let me know what happens, I can help with this ;)
Nov 02, 2010 | Apple 24" iMac Desktop
My 24" Aluminium iMac (early 2008 model) with 2.88Ghz 320g hard drive and 4g rams would freeze out of nowhere...I have ran various program tools to scan (tinkertool, DiskWarrior etc) soft and hard ware but...
Thank you for contacting Fixya Support, I am glad to assist.
In cases where you are experiencing issues with your iMac 24" and you have already tried hard drive and software repairs (including Tinkertool and Disk Warrior), one troubleshooting step I would recommend you try is unseating and re-seating your RAM card one module at a time.
Once you have tried this, then run Disk Warrior, run the Repair Disk Permissions (at least twice).
Once you have run the Disk Repair option, then perform a Disk Rebuild (it will not remove your files from your hard drive but actually rebuilds the Mac OS X directory) and reboot your iMac.
Try this procedure and see if that makes a difference in your iMac's performance.
Let me know if this helps.
Regards,
-Mactechtrainer
Sep 03, 2010 | Apple iMac 24" Desktop
24" iMac 3.06 GHz Intel Core 2 Duo Desktop Computer With Wireless Keyboard And Mouse - Z0FHW Mac Desktop: I have tried to repair disk by doing an archive an...
When you used the archive and install feature on the installation did you remember to preserve users. If you did not, all you have done is archived the system which will show up as a folder called "Previous System" and none of your files. What I would do is have a look in the users directory the top level of your hard drive and see if there is an archive folder or disk image in there.
May 16, 2010 | Apple 24" iMac Desktop
Computer Froze
Use your Boot OS disks to boot from and remove the file and anything in the start up folder that you dont know what it is. If that doesnt work you may have to reformat.
May 14, 2010 | Apple 24" iMac Desktop
My imac wont turn on!
It sounds like something is either corrupted on your system or one of the files in your imac may be suspect. What I would suggest is get your system disc boot the imac down holding down the c key on your keyboard. Once it is booted up go to the file menu and find the disk utility. Open up the disk utility and first of all repair your disk permissions and then run disk verify and if an error comes up choose to repair it.
If this does not work. I would suggest installing a clean system. Again with the system disk in your computer restart your machine with the c key held down on your keyboard. Choose to do an install but remember to select preserve users. This will give you a clean instal with your files and preferences intact.
Once your machine has restarted it is well worth setting a second account under system preferences under accounts as if one account becomes corrupt in the future you have a second account to fall back on.
For prevention of any problems in the future I would download Onyx from this website http://www.switchingtomac.com/tutorials/keep-your-mac-running-smoothly-with-onyx/ which also talks you through the method of using it. I use it every month just to keep my mac in tip top condition.
Hope this helps.
Apr 03, 2010 | Apple 24" iMac Desktop
Imac G5 keeps freezing on turn on
Get out your Mac OS disc and restart your computer and get that disc into the drive. You may need to restart with the disc in, but that's ok.
Just restart again with the "C" Key pressed and the computer will launch with the OS disc, and then you can access the file menu when it finishes launching.
Choose "Disk Utitlity" from the file menu and you can repair the system files on your hard disk.
then restart without the disc in the drive.
K
Sep 14, 2009 | Apple iMac 24" Desktop
Imac freezing
Few Questions answered can help me out.
1)Did you update the OS
2)Did you install any drivers recently
3)did you install any software's
4)is any external devices connected when facing this problem
5)did you put new RAM inside
6)did you try to boot from the DVD disk 1 and repair hard drive using Disk utility
This can easily help to resolve the problem
Dec 02, 2008 | Apple iMac 24" Desktop
Apple 24" iMac Desktop Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
