Question about Samsung SCX-6322DN All-In-One Laser Printer
6322dn gmail configure gmail smtp
How to configure gmail SMTP setting for outgoing server?
Process to configure gmail SMTP setting for outgoing server
Gmail provides email services to user.It is used for sending and receiving mail.It is freely used by users.It is developed by Google.If you create an account an G mail then you can directly open your Google account there is o need to create another account. It provides unlimited space to user. For some Business application Gmail is used as paid .Gmail is used as open source.
When you use Gmail then you need to check that your server is connected to Gmail or not.You should know that Gmail SMTP server is used for sending email from your Gmail account. SMTP is Simple Mail Transfer Protocol ,it is used for every email account but it is not same for all the accounts.so for Gmail Account you need to configure Gmail SMTP settings then you need to follow these steps:
First you need to go in the Email client software then you have to go in the outgoing mail
first you need to check that your Gmail SMTP server Address that should be SMTP.gmail.com.
Then you have to enter your Gmail SMTP user name ,your SMTP user name should be same as your Gmail address.
Then You have to enter SMTP Gmail password,it will be your Gmail password.
Now you have to enter Gmail SMTP port number for TLS and secure socket layer connection.
Then you have to select "Use SMTP authentication".
Then you have to click on YES if if you see that Gmail SMTP TLS/SSL required.
Then your SMTP server will be set to your Gmail client.
You can easily configure your SMTP Gmail Setting with the use of above steps but if still you are not able to configure your SMTP settings then you can contact Gmail Technical Support for any query .They will provide you best solution.
GET INSTANT SUPPORT FOR YOUR GMAIL ISSUES NOW
Jun 15, 2017 | Computers & Internet
I have samsung s5233 mobile phone and i cannot configurate my gmail account in my mobile , kindly help me
Gmail Settings For Samsung Star Cellphones:
Go To > Menu > Messages
Click Settings > Email
Then Touch >Email Setup Wizard
Notice will ocuur Touch > Ok
Give name to your account E.g Gmail
Enter your email id : yourname@gmail.com , Then Enter Password for your account.
Incoming Server type : POP3, Incoming Server : pop.gmail.com
Outgoing Server SMTP : smtp.gmail.com, Secured Connection :Off
Then touch OK & it will display your POP3email account configured successfully. Now press back button and tap on Email Accounts, then touch the email account you have just created. There some more options you just have to edit such as:
Secured Connection:Off, POP3 Port:995, SMTP Port: 587
Now,Tick The option APOP Login., Download Limit: 500
Secured connection: SSL (Choose SSL for second option only & not for first option.)
Retrieving Option: Choose Subject only
Keep On Server: Tick
My Address: youraccontname@gmail.com
Username /Password : same as you entered above
POP before SMTP : Dont Tick
SMTP Auth: Tick
Same as POP3/IMAP4 : Tick
And Finally Save All Settings and your gmail account is set up.
Sep 17, 2011 | Samsung Star GT-S5233 Cell Phone
Magic Mail (in Magic Desktop) doesn't work with Gmail account. The message is "error adressed" My settings: imap@gmail.com smtp@gmail.com + autentication smtp port:465 pop3 port: 993
I downloaded and installed Magic Desktop and configured Magic Mail. It works with Gmail, but it seems to only support the POP3 server for Gmail. In other words, you must use pop.gmail.com, not imap.gmail.com. You also need to enable POP email in your Gmail settings.
Hope this helps, Eric
Apr 30, 2011 | EasyBits Software Magic Desktop
I am unable to setup my email wizard in my samsung corby
Standard instructions for email inbox setup:
i have finished my corby pro email settings & i can send and recieve emails. the problem with only recieving & not able to send is the confusion between port numbers. in secure connection box three options available ' off ', ' SSL ', ' TLS '. use only SSL or TLS because the port numbers for SSL & TLS differs. just try this & you will be able to send and recieve emails.
                                                    SMTP port - 465
                                                    POP3 port - 995
Enable POP in Gmail. Don't forget to click Save Changes when you're done.Configure your client to match the settings below:Incoming Mail (POP3) Server - requires SSL:pop.gmail.com
Use SSL: Yes
Port: 995Outgoing Mail (SMTP) Server - requires TLS or SSL:smtp.gmail.com (use authentication)
Use Authentication: Yes
Port for TLS/STARTTLS: 587
Port for SSL: 465Account Name:your full email address (including @gmail.com or@your_domain.com)Email Address:your email address (username@gmail.com orusername@your_domain.com)Password:your Gmail password
Unless you're using recent mode to download mail to multiple clients, make sure you've opted not to leave messages on the server. Your Gmail settings determine whether or not messages stay on the server, so this setting in your client won't affect how Gmail handles your mail.
Please note that if your client does not support SMTP authentication, you won't be able to send mail through your client using your Gmail address.
Also, if you're having trouble sending mail but you've confirmed that encyrption is active for SMTP in your mail client, try to configure your SMTP server on a different port: 465 or 587.
You're now ready to use POP with your Gmail address.
Mar 08, 2011 | Samsung S3653 Cell Phone
How to configure the email ?
Hi there!
Here are the steps to configure your Samsung Star GT- S5233 cell phone:
Go To > Menu > Messages, Click Settings > Email
Then Touch >Email Setup Wizard. Notice will ocuur Touch > OK
Give name to your account E.g Gmail. Enter your email id : yourname@gmail.com , Then Enter Password for your account.
Secured Connection : Off
Then touch OK & it will display your POP3email account configured successfully. Now press back button and tap on Email Accounts, then touch the email account you have just created. There some more option than above you just have to edit that.
Secured Connection: Off
POP3 Port: 995
SMTP Port : 587
Now, Tick The option APOP Login.
Download Limit: 500
My Address: yourname @gmail.com
SMTP Auth: Tick
And Finally Save All Settings.
Jan 27, 2011 | Samsung Star GT-S5233 Cell Phone
Hi my name is pandi.c i configure the mai id but smtp authentication error is occured any pls help me
Hi pandi ci smtp autthentication error occurs if the email id or password you configured is wrong or the smtpserver did not respond. the authentic email id should have the same extn as the smtp server
for example:
if your smtp server is smtp.gmail.com ten the authenticating email id should be xxxx@gmail.com.
the error also comes if the smtp authentication has been enabled. you can disable it and send docs without authtion . contact you sys admin . ok hope this helps u . bye
Narasimha kumar (INDIA)
Jan 19, 2011 | Canon iR 2016i Black and White Copier
How to configure email for samsung gt-b5310
GO TO UR GMAIL ACCOUNT SETTING AND ENABLE IMAP. account name: Gmail SMTP server: imap.gmail.com SMTP port: 465 secure connection: SSL Incoming server type: Pop3 Pop3 sever: pop.gmail.com APOP Login : ticked Secure Connection: SSL Download limit: 500 Retreive option : whole messge Keep on server: ticked my email address: *****@gmail.com username:*****@gmail.com pssword: **** POP before SMTP: unticked SMTP auth: ticked SAme as POP3/IMAP: ticked
Sep 06, 2010 | Samsung Cell Phones
What iis the outgoing/incoming server for gmail?
Google GMail Settings
The Google GMail service offers email client access for retrieving and sending emails through your Gmail account. However, for security reasons, GMail uses POP3 over an SSL connection, so make sure your email client supports encrypted SSL connections.
    Google Gmail Incoming Mail Server (POP3) - pop.gmail.com (SSL enabled, port 995)
    Outgoing Mail Server - use the SMTP mail server address provided by your local ISP or smtp.gmail.com (SSL enabled, port 465)
May 03, 2010 | HP Pavilion dv6000z Notebook
Samsung SCX-6322DN All-In-One Laser Printer Logo
51 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
