Question about Casio Privia PX-350 88-key Digital Piano White w/Wood Stand & 3
Casio privia px-350 key too loud
One key too loud
SOURCE: Casio Privia Px-120 88 key digital piano frozed.
Hiya,
I had the exact same problem and the piano is brand new! I considered the possibility of the above answer as I had plugged it in via a power cable (it was missing the 3 pin UK plug) and it was also plugged into a power strip. My dad also looked at it and couldn't see why this should cause it...but I tried the different combinations anyway...including with the proper 3 pin plug attached to the adaptor (when it arrived in the post), rather than a power cable. This was the result:
Power cable +power strip = piano froze
Power cable (straight into wall) = piano froze
Proper 3 pin plug supplied + power strip= piano froze
Proper 3 pin plug (straight into wall)= piano froze!!!!
So....in answer to your question...I'd say there's something wrong with the piano! If not, it should've worked for me on the correct combination. :I I will now be returning mine. I worry what the cause is though considering my piano is brand new....and therefore is this a fault that regularly occurs with Casio privias? I don't want to spend this much money on one if it's going to do this eventually.
Posted on Jun 23, 2009
  • 5603 Answers
SOURCE: I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Posted on Dec 01, 2009
  • 5603 Answers
SOURCE: Casio Privia PX-800: When using the sustain
Check if the cble frm the pedal MIGHT be flexing or pulling on the keyboard case when you use it. Such movement COULD vibrate the power connector causing your problem.
Make sure you have the right power supply for the unit as one with too large a hole for the power pin would be intermittent like this.
Posted on Jan 26, 2010
  • 5603 Answers
SOURCE: casio privia key issue
The only way to analyze this is to open the case. You may find contaminating material has gotten in, or broken part, or key slightly out of position on pivots or pivot plastic broken.
When opening, be VERY careful of the tender ribbon cables. Have a large work surface that you can unfold the top onto. Be careful to use correct screw lengths and thread in each place you removed.
Posted on Apr 27, 2010
mcdevito75
  • 1970 Answers
SOURCE: How do I replace the lithium battery in a Casio
mcdevito75 here, I've also riuned a number of Casio watches replaceing the battery, extra, extra care is needed, first remove the back cover screws, then you:ll have to remove another cover for the battery, after replaceing the battery the work begins, very carefully reverse the removal procedure, any un do pressure will cause the movement to break and the face of your watch will turn Black. Best with your casio is to let a watch repair shop change the battery, look for a small shop to save some money.
Posted on Jun 16, 2010
What is causing noises in my Casio privia Digital piano?
Pivots worn out or need lubricant. Make a warranty claim first.Otherwise, If out of warranty I would try to lubricate the hammer pivots myself. You will need "grease suitable for plastics".
Jun 10, 2014 | Casio Privia PX-350 Digital Piano Black...
What is causing noise in the keys of privia px350?
Try using a can of pressurized air to clean around the keys that are noisy.
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Apr 27, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Casio privia px-750 how to do a factory reset?
HIS WORKS ON MOST. Turn the keyboard off.Hold the C note down at the far right of the keys.The very last C note.Keep holding it down and turn the keyboard on.
Jan 19, 2014 | Casio Privia PX-750BK - 88-Key Digital...
How to fix loud key on Privia PX-830
I just fixed mine, it was making the loud sounds and had seemed to have lost the sensitivity. Take out all the screws on the outside, then the sides can come off. That gives access to the inside where you can take out a few more screws (easily seen) and open it all up. The keys themselves just snap in, so two small screwdrivers or strong fingernails can pop them back out. Clean the rubber contacts (they look like little sockets) with Q-tips and rubbing alcohol, then replace the keys. If you take out the white keys of an octave first, then the black keys (keeping them in order) it is a lot easier.
Jun 18, 2012 | Casio PX-830 BK Privia
I have a Casio Privia PX-130 and I tried to turn it on and it wouldn't turn on. I have noticed lately that when I would be playing a song that when I pressed a certain key that it would make this...
Test the adapter with a meter... Most probable cause is a bad power connector. Often the solder at the input power connector breaks loose is only problem. If you are not electronically adept, best to take it to a shop.
Jun 27, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
Nov 30, 2009 | Casio Music
Casio Privia PX-350 88-key Digital Piano White w/Wood Stand & 3 Logo
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
mikeuk
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
