Question about Hardware & Accessories
Weiser door knob GA9771A-S. Loose interior door knob. How do I tighten?
How do I tighten loose interior door knob?
Remove the knob by pushing in the small pin on the edge of the knob shaft. Then use a screwdriver in the small inset on the edge of the handle cover to pop the cover off. Tighten the 2 screws under the cover, replace parts.
Posted on Aug 29, 2014
How to tighten-up loose door knob?
What door knob are we talking about,, a door knob has screws on the back side, usually a #2 phillips head screwdriver will work in the screws.. If you are talking about a different knob.. please repiy on here... please mark as helpful..
Jul 18, 2017 | Hardware & Accessories
How do I tighten my Weiser front door handle
Depends on the model. Usually there are 2 screws behind the trim plate that you need to tighten. The handle may need to be removed, to take off the trim plate so you can get at the screws. If that's the case the handle will have a small pin on the shaft someplace. Push the pin in and pull the handle off. Then carefully pry the trim plate off, tighten the screws and reinstall everything.
Feb 09, 2015 | Refrigerators
I have 3 door knobs on outside doors that are loose and need to be tightened. the knobs have come completely off sometimes when we go out the doors. how do I tighten the knobs so they are not loose?
On the inside side of the door knob, there is a decorative plate. Depending on which model door knobs you have, it is held on with a "set-screw" that might require an allen-wrench (looks like an 8-sided tool; usually in an L-shape), or just simply a screw driver, to loosen and remove it. Once you take the decorative plate off, there will be two very obvious screws that hold both sides (inside and outside) of the door knob together. Tighten these screws to tighten your knobs, then put the decorative plates back on again.
Feb 27, 2011 | Kwikset Professional Door Lock...
Back door handle on my back door is loose and has alot of play on it
If it is not the OLD style door knob, tighten the two screws next to the knob. If that does not fix it it will probably need repleced.
Feb 21, 2011 | Garden
The driver's side outside door handle is loose, toyota celica '95
I assume that the entire handle unit is loose in the body work of the door.
The interior door trim will need to be removed to access the inside of the door to fix the loose handle.
Do not attempt his yourself unless you have some experience in this area.
Take the vehicle to the nearest reputable auto body repair shop and they can easily fix it for you. There could be a breakage on the retaining system on the handle or the retainers may just need tightening.
Typically door handles which have not been subject to damage or abuse will not usually loosen like this. It's possible the door was damaged and the panel repaired and repainted at some stage. If so the door handle may have been removed and refitted in a sloppy manner.
Dec 03, 2009 | 1997 Toyota Camry
How do I remove the doorknob from a weiser passage set? Want to paint door and remove passage set. Can't seem to find any slot to remove doorknob.
Door knobs have an escutcheon plate (The round part that touches the door ) that covers the screws attaching the knob together.
To get the knob off first look along the shaft of the knob ( The straight part between where you grab the knob and the escutcheon) there should either be a allen head screw or just a metal button. If its a button push in on it while you pull the knob away from the door or if its a screw just unscrew it either way the knob will come off.
Now look at the edge of the escutcheon where it touches the door. On some models there's a little detent or hole where you can put a small flat head screwdriver in to pop the escutcheon loose from the plate. If there is no detent or hole then it may be screwed on. Just grab the escutcheon and turn to the left.
Once you get the escutcheon off you'll be able to see the screws that attach the door hardware together. Just make sure to pay attention to how you took it apart so it goes back the same way.
Hope that helps !
Nov 03, 2009 | Hardware & Accessories
I have a 2008 Honda Pilot. Today the rear tailgate light come on, and all the interior lights came on and stayed on. I got out and slammed the rear door to make sure it was closed. I then continued to...
the light switch nut holding the tial gate light on is loose or the wires are loose and touching. It is a easy fix look for the contact plate for the switch and see if the knob is loose tighten it up. if you don't know where it is then go to a partssstore and ask them they can show you where it is located. Since it is new It should be covered under warrenty so call your dealership and ask if it is a free repair.
Sep 28, 2009 | Honda Pilot Cars & Trucks
Uline beverage fridge loose door handle.
Hi
You are right. The only way to repair this is by replacing the complete door assembly. If under a year it should be covered.
Jun 06, 2009 | Refrigerators
Plunger sticks in when installing weiser locksets
Try enlargeing striker hole with tiny dremel electric sand drum disc. Throw bolt is binding and you may also try looseing all install screws and tighen each one at a tme as you test plunger each tighten until you have success,do not forget to unloosen throw bolt screws to.
Mar 19, 2009 | Hardware & Accessories
Hardware & Accessories Logo
477 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
