Question about LG Cell Phones
LG NB2520 SOUND BAR INSTALATION INSTRUCTIONS ALL WIRES & CONNECTERS
A PICTURE OR INSTILLATION ALL CONNECTIONS & WIRE'S HOW TO GUIDE
5 Suggested Answers
SparkGap
  • 363 Answers
SOURCE: Hooking up speakers to amp
YES ! This is usually ok, the speaker cabinet should contain a high pass filter or crossover on the tweeter to decouple it from the low frequency signals. My Linn Index speakers are wired like this.
Posted on Sep 22, 2007
kidsasuke
  • 121 Answers
SOURCE: Bought LG Plasma 106cm in 2008 HD
Your screen may have either burnt out or became disconnected somehow. Sometimes, it's as simple as a connector coming loose from its port; other times, however, there's physical damage to the wires/connector/port. I'd contact the manufacturer to troubleshoot it as far as it can go on the phone. I assume that they'll either figure it out right there, or follow their protocols and (assuming it's covered in the warranty) have you send it to them for diagnostic steps. The other alternative is to simply call a professional.
Posted on Jun 03, 2010
  • 884 Answers
SOURCE: start relay has different number of connections
The new relay only needs a switched live and a neutral. The lives for the rest can be joined together (they were on a joint connector on the old relay) and the neutrals are common anyway. The switched live is the one that comes back from the thermostat control.
Posted on May 16, 2012
jamessizer81
  • 7515 Answers
SOURCE: 2006 Solstice. Why is there no sound?
Pontiac
for better result download the pdf file
Posted on Apr 18, 2016
How to wire to the battery
simple red goes to posit terminal and black goes to neg term use connecters on end of your wire in shape of u shape to place around bolt on terminals dont just wrap wire around terminal if you need longer wire use connecters crimping onto your cb wires no less than 12,14gauge wire
Jun 28, 2015 | Radio Communications
I have a Kenwood kac-628 amp and it turns on but only red lights. All wires are good and have good connections. I opened it up and there is a brass looking piece that seems broke. Maybe a piece is missing...
Disconnect the speaker wires from the amp side. Turn the amp on. Within about 5 seconds you should hear a faint click from the amp. If you don't hear the click, the amp probably has a problem. ie. Shorted outputs. If you hear the click reconnect one speaker and turn on again. If you don't hear sound disconnect that speaker and connect the other. If you have sound with either speaker the one that is disconnected is the problem. Check speaker wire carefully for frayed ends touching each other.
You can swap the speakers at the speaker end one at a time, to determine if it is the speaker or the. Wire.
Feb 02, 2015 | Kenwood Car Audio & Video
I have a crosley record player, the kind that can play CDs, iPods, tapes, and is a radio too. When I play records either no sound comes out of one side or just static. Both sides get static though. It's...
It's possible that the wires that connect the cartridge where the stylus fits are loose or broken off. With it set to the deck, have the amp on. Lift up the arm and touch the wire connections to the cartridge. You should hear a buzz on each of the channels depending on which wires you touch. You can also disconnect the wires from the cartridge and carry out the same test. On one wire it will buzz on the right, on the other on the left. The two other wires are earths and will cause only a slight buzz or nothing at all. This test proves the pre-amp inside the amp is working. If the wires are connected properly to the right connections on the cartridge, you should hear sound. If the connections are good and the sound poor or absent you need a new cartridge.
Aug 24, 2014 | Audio Players & Recorders
My turntable spins but has no sound output. the tone arm and needle appear to be in proper working condition.
If you disconect the wires to the cartridge you can check if the sound is getting to the amp. With the amp switched on and the turntable connected, touch each wire one at a time with your finger. You should get a buzz on one wire on the left and one on the right with another. The other two wires won't give off any buzz. If you don't hear the buzz on either channel, either the connections linking your amp are faulty or the magnetic cartridge pre-amp inside the amp has failed. If you do hear the buzz then the cartridge is faulty or the connections to it are bad.
Nov 19, 2010 | Vestax PDX-2000MKII PRO Turntable
I want to install a cutler hammer 20amp. cuircut breaker in my home. i need instructions on how to wire it up in the breaker box. can anyone help?
20 amp 120 or 240? All 20 amps 120 must be 12 gauge wire for all connections on that circuit.. no exceptions
120- Bring wire into box securely as is done with all the other wires. Shut the breaker to "off". wire the black wire from the screw on the back of the breaker. white wire to the bar with all the other whites. copper to the same bar or separate grounding bar if available. snap breaker into place. turn breaker on
Oct 13, 2010 | Cutler Hammer Qcd2060 Circuit Breaker
Jun 03, 2010 | LG 42PB4D 42 in. Plasma HDTV
Amp is on but no sound.....also amp stays on when car is turned off
sound is more like a speaker conection problem. than your amp. check your speaker connections first. to make sure they are plugged in all the way. and fit tight on the speaker. it they are . and it is still cutting out. you may need to trace the speaker wires. and see if they are getting pinched in the door jam. that is a usual culprit for speakers cutting out.
Aug 03, 2009 | Car Audio & Video
Need wireing diagram for instalation
Hello bulldogwjm,
You can download the Kenwood manual here:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Just select the model number from the dropdown and download it.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
My amps not working anymore.
first check your ground wire then you power wire connections .. check the fuse to see if its making connections on both ends of the wires..
i think the flickering is the result of a weak or bad connection in the power ground or acc wire "normaly blue"
your amp has no sound because the amp has to charge before it can out put at a higher amperage
hope this helps
Dec 21, 2008 | Car Audio & Video
42 plasma tv no picture but have sound
Try pluging in the euro connecters in tight on the back of the set or in some cases HDMI cables
Jan 30, 2008 | LG 42LC2D 42 in. LCD HDTV
Cell Phones Logo
13 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
