Question about Integra Onkyo Rc-711m Dtr-4.9 / 5.9 Replacement Remote
"handshake" between DTR 5.9 and an LG Blu-ray player
I have an Integra DTR 5.9 and an LG Blu-ray player, (plus DTV, which works fine!). My problem is that it take up to 30 minutes for the Blu-ray player to "connect" with the dtr 5.9. After that, all is good for Disks, netflix, etc. help? Thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 137 Answers
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Posted on Feb 25, 2015
3 Suggested Answers
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
SOURCE: the reciver dosnt get a signal from the hdmi
HAVING THE SAME PROBLEM. omg. maybe there is help. will get audio but no video from DPS dvd player and PS3. no onscreen menu either. changed hdmi cord. seems to be problem with reciever. DVD works fine when changing to component cables instead of the HDMI. sometimes plugging and unplugging the HDMI cable gets the PS3 working. Don't quite understand scrap605's suggestion. but that doesn't solve this prob.
Posted on Mar 07, 2010
My LG AKB73375501 has stopped interfacing with my Blu Ray player but interfaces with my TV. I can only control my Blu Ray player via my TV remote. How do I get my LG AKB73375501 to interface with my
with lg this is normal and there is nothing you can do beside to take the set in for a exchange or repair service- I have an lg device or two that has the same issue, it is the players not the remotes. if i find a solution i will update you good luck questions just ask
Mar 30, 2013 | LG ELECTRONICS Remote Control AKB73375501...
Region hack for lg bp125
My LG Blu-Ray player (BP 125) resets every time I play the Movie "Brave" at the 5m30s mark. If I skip it it, it is fine. I searched the LG site for answers but to no avail. Any ideas out there what to do? it is not a network or wifi player, it was the $38 special walmart had on black friday. i am on my 2nd copy of this movie and all of my blu rays I own work on it fine. Any solutions or suggestions will be welcomed.
Oct 23, 2012 | LG Televison & Video
Have an LG LHB306 blu-ray player. Worked fine until today. Put disc in , states
If it states no disc, cannot read, etc you have either a dirty or bad optical pickup in the unit.
Jun 17, 2012 | LG BD370 BLU RAY PLAYER
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
WE HAVE AN OLDER LG BH200 BLU-RAY DASC PLAYER THAT WILL NOT PLAY A NEW BLU-RAY DISK. WHAT IS THE PROBLEM AND HOW DO WE FIX?
It may need BD Profile 2.0 Some players will not play discs if this is not present. All new BD discs are BD Profile 2.0
Dec 25, 2010 | LG BH100 Blu-Ray Disc Player
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Mar 01, 2010 | Integra DTR-5.1 Receiver
LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
Sep 18, 2009 | LG LXD5230 System
No sound from speakers from components with Integra 6.9 receiver
Turns out it had to do with one of the settings for the new Blu-Ray player.
Thanks anyway.
Jan 17, 2009 | Integra DTR-9.1 7.1 Channels Receiver
Integra Onkyo Rc-711m Dtr-4.9 / 5.9 Replacement Remote Logo
144 people viewed this question
Top Integra Audio Players & Recorders Experts
Electro Med Services...
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
