Question about ASUS Computers & Internet
Asus x61z cmos battery replacement - ASUS Computers & Internet
2 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: CMOS replacement for ASUS d1
It's difficult to say but you will need to remove the underside screws and also maybe even the keyboard as it's often attached to the base. The cmos battery could also be behind the screen. Comment by sandrew, posted on Nov 12, 2006 I'm sorry but I dont have any personal experiences with your particular laptop, but the lcd's are generally held in with 1 screw in each corner normally covered by a rubber bung hiding the screws, I would be very carefull not to disconnect any wires behind the screen, if yor not sure take it to a qualified repairer. You will probably have to remove the top panel just below the hinges as they may be held in underneath
Posted on Nov 13, 2006
How can you change cmos battery in asus f3jc laptop
I think it is under the RAM. Here is a link in case it is on the other side of the motherboard.
Asus F3S Asus F3S disassembly How to replace HDD RAM
Oct 10, 2016 | ASUS Computers & Internet
ASUS ALL IN ONE computer ET2221i-b85 The time is not correct and keeps losing time. I want to replace the cmos battery .
Keeping time has always been a problem for computers, as their internal clocks needed something to synchronize with. If you have an Internet connection and use Windows, you can get the time adjusted regularly using a time set function from Windows online. The CMOS battery will have little to do with time settings, unless it goes bad. Then, not only will your date and time go out of sync, so can many other settings in the CMOS. So, unless you are getting a low battery warning, or both the date and time are out of sync, you probably don't need a new CMOS battery and replacement probably won't fix you time drift issue.
In Windows 10, to get auto time sync, go to "Settings", then select "Date and Time". Under this you will see an option to "Set Time Automatically", as well as to select your time zone.
Aug 19, 2016 | ASUS Computers & Internet
How can I replace the CMOS battery an ASUS laptop?
There is no replaceable CMOS battery on this model.
It is probably a rechargeable battery on the motherboard.
See Manual which only mentions the main battery pack.
http://dlcdnet.asus.com/pub/ASUS/nb/UL50A/T4786_UL50.zip
Mar 15, 2015 | ASUS UL50Vt Notebook
Replace cmos battery and case openning
Asus motherboards usually use a lithium CR2032 battery for CMOS. Also, on the top of the old CMOS battery you took out there should be the exact battery type engraved on the surface.
Batteries Plus in Wichita, KS has a good online store for purchasing your replacement battery.
Dec 12, 2013 | ASUS CS5111-AP007
ASUS P5GZ-MX: Cmos Settings Wrong - Tryed New Cmos battery and setting time a date howto fix ?
It may just be that the new battery needs to be charged. I would leave it switched on for 24 hours to check. If this doesn't fix the problem, it could also be a failing BIOS chip or the charging circuit for the CMOS battery has failed. If the BIOS chip is not socketed or the cmos charging circuit has failed, you will need to replace the motherboard or find an electronics engineer to replace the failed components, this will probably be more expensive that a new board.
Jun 13, 2012 | ASUS P5GZ-MX Motherboard
Is the cmos battery rechargable y the Asus Eee PC 1005HA model
It should be a "trickle" charge, i.e., just turn it on, and a small amount of current will be used to recharge the CMOS battery, in the same way that driving your car recharges your car's battery.
Jan 21, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I replaced the cmos battery of my asus eee top et1602, now the compunter doesn't boot
remove the cmos battery and with a piece of conductive wire shrt negative and positive terminals for around 5 seconds then replace the cmos battery, ensure power lead is disconected, this may help
cheers
paul
Dec 22, 2010 | ASUS Eee Top ET1602 PC Desktop
No power detect for asus p4s533
clear cmos in motherborad....jumper is near battery....set jumper at 2-3 pin for 5 seconds....and then return it again at 1-2 pin.....if doesnt work,please remove cmos battery and replace new cmos battery...
Oct 15, 2009 | ASUS P4S533-MX Motherboard
Need to reset Asus k7v bios
Yes, if you consult your motherboard manual this will show you the location of the cmos battery and reset jumpers. You can either move the jumpers from pins 1+2 to 2+3 and then back again after a few seconds or remove the cmos battery for a few seconds. Make sure your pc is off!
Dec 16, 2008 | ASUS VIA KX133 Chipset K7V (K7V/500/SWA)...
Nov 11, 2006 | ASUS Degatto Notebook
Computers & Internet Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
