Deltaco Hi there. Did any can help me. I need the controller board in the cabinet. Not in the hard drive. Have an DELTACO MAP-HL 27 U 3. Waiting for any reply. Thank,s
  • 3,320 Answers
The cost of fixing low-cost electronics is prohibitive. Most are built with the view that they cannot be opened without damaging the product. Parts are not available from the manufacturer because they are assembled in China and the components are ordered for a run of complete products, not spare parts. If you think it is your only option, most electronic repair shops can figure out circuits and components, but be prepared to be charged more than you paid for the product.
Asking for replacement components on Fixya is fruitless. Unless some has taken apart a product EXACTLY like your own, you will get no answer.
Posted on Mar 31, 2014
Print unable 27
Printer detect motor/drive problem. Check harness, motor or main board.
Apr 12, 2014 | Brother "hl-4570cdw color laser printer...
I have interl board.the fan of processor is working after some time disply come but after this the board not working.pl.help
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 25, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Hard drive not recognized
1. your hard drive may have come to what is call "end of life" cycle
2. You didn't designate if you have a internal / or USB drive.
3. If this is an IDE ( internal Drive) then you will have to enter the PC cabinet to check.
4. IF this is a USB drive some time the electronic controller board is malfunctioning and will not transfer data from the processor on the data board to the USB cable.
5. If it is USB the usb cable it self is damaged due to strain at the strain relief.
6.The PC Mother board may have lost it's ability to recognize the hard drive.
Apr 15, 2010 | Iomega HDD External Desktop (32660) 80 GB...
I need a driver for my sound card
how i solve problem plz contact yhis email shaurakhkhan@yahoo.com
May 28, 2009 | IBM Computers & Internet
The p4i45gv powers up for two seconds then shuts off
Remove ur SMPS and reinstall by ur new SMPS and enjoy it.
Mar 14, 2009 | Asrock P4I45GV R5 Motherboard
Ugrading
The message would be expected since there is no hard drive. Partition Table refers to information about primary partitions and an extended partition a 64-byte data structure located in the same sector as the Master Boot Record inside the hard drive.
This might be of additional help.
Hope that this be of initial idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 22, 2008 | Panasonic Toughbook CF-27 Notebook
How to retrieve data from external drive
I had similar problem. See FAQs on this site. My 300 GB One Touch II drive was not found in the XP machine either as USB or IEEE. When I remounted the drive in an external cabinet from Deltaco ( MAP-KC) is is running since. The Maxtor chassi was the trouble not the 3,5 " drive. All data is recovered. // Regards AH2FOTO
Sep 24, 2008 | Maxtor OneTouch II external hard drive...
Hi tried that... sound card is connected and vm-ware tools is also installed... its surely a problem with the windows 2003 server. because the error sound is played through the macbook speakers but not any...
see heres the thing when using VM-Ware, VM-Ware doesnt use drivers for your physical hardware, because it emulates the hardware that is seen in the hardware information of your system preferences.
So installing even drivers for the "emulated" hardware will not work, as VM-Ware uses its own drivers for the hardware, which are included with the VM-Ware Tools, if that doesnt seem to work, you may want to contact VM-Ware support, as they may have a better solutiuon.
Aug 29, 2008 | Intel Motherboard
Lost color on Samsung TX-R2735
You may have a loose solder connection on a PC board in the color circuits. You might try jarring the set by hitting it at different places on the cabinet. NOT TOO HARD ! Like not with a hammar. If there is a loose connection it may show up. Also check to make the color level control hasn't gotten turned down. Hope this helps. Sometimes when you move a set you flex the circuit boards. If there is a poor connection it may show up--- in your case in the color circuits. Stargazer
Aug 11, 2007 | Samsung TX-R2735 27" TV
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Online Cloud Backup their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Computer Data Backup with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in Business Server Data Backup provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
May 24, 2018 | VIA Computers & Internet
Computers & Internet Logo
David Payne
David Payne
