Question about Mitsubishi WS-55905 55" Rear Projection Television
I have a mits ws55905. The problem i'm having is when I try to turn on the unit, the green light turns on then turns off about a second later. This TV was given to me. I was trying to make it work. It's really a nice looking TV. Hope it's worth fixing.......
  • Mitsubishi Master
  • 8,617 Answers
Press the menu and input/device buttons both in together and hold for 5 seconds and see if the led will blink a two digit error code such as 2 blinks slight pause then 2 blinks again indicating a 22 code. Try that and then let me know what the blink code was.
Posted on Jun 15, 2009
I have a 42" Maxent plasma tv. When turned on,
one or your tv mainboard was crashed, change it with new one
Jan 18, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Green edge around images (outline)
my 2002 sony wide screen projection tv has menu and pictures when turned on first thing in the morning?
Jan 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Ws65711,8 years old, working great with out problem until this one..turned off the tv normally after use, then when tried to turn on again... it turns on (green light turns on. no pictureno...
SD TECH,
Just started experiencing convergence problem with my Mits ws-65711. I have decided to try to repair on my own and have the service manual. I see also you have step by step instructions for the repair and perhaps photos of the fuses. I could really use this info if you are able to provide.Thanks in advance. I did the self check by holding in MENU and INPUT buttons and got 1 green blink followed by 2 shorter/quicker green blinks?
Aug 30, 2009 | Mitsubishi WS-65711 65" Rear Projection...
Mits Ws 5551 won't turn on
http://www.techlore.com/forum/thread/19174/Green-Blinking-Light-on-Mitsubishi-HDTV/?page=26#43124
Go to this post. I had the same problem and it was easy to fix...it cost about 26 bucks total and took about 20 minutes start to finish!
Bruce
Jul 20, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv won't stay on
2 of 3 circuit boards in your Mits can give your symptom...
1)Center power supply board = open fuse & bad IC's
2)HV scan board defective.....
A qualified Mits tech with parts in stock can fix it.......T.
Dec 13, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WS-55905 55" Rear Projection Television Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
