Question about Proselect Heating & Cooling
Thermostat temperature settings
How to set settings to stay
Destinova
  • 46 Answers
SOURCE: problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
Posted on May 27, 2008
  • 85 Answers
SOURCE: my honeywell thermostat Modle: RTH7500D
If your manualy setting the program and it kicks itself off, then your therm is bad, look for your warranty paperwork, or call the distributer and give them model and serial, they can point you in the right direction. If your setting a temp and not manualy holding, then it will set back by default. Check your other settings, ensure they work as well..
Posted on Dec 05, 2008
  • 306 Answers
SOURCE: Furnace doesn't reach desired temperature
One of two things you can try. Do you own a volt ohm meter? Anytime your unit cycles short like it is doing the control circuit which on this one is 24 volts that engages relays and controls the gas valve to open and close. I am thinking the heat exchanger is getting so hot it is tripping the upper limit which for the most part is around 180 degrees. So next time it turns off take your ohm meter and with the power to the whole unit off. Either turn the breaker off or there is a light switch that is real close to unit turn it off. Undo the two wires to the gas valve and ohm them out. You should have continuity if you get nothing check each limit switch should have a couple. Undo wires to them and check. If you find one that is open more then likely the upper one. They are a safety device that keeps the unit from getting too hot.
There might be another option increase the speed of your fan motor to get the heat out of furnace quicker. Look at the circuit board notice the fan wiring going to it. The Red wire from fan is low speed look to see if it is on HEAT on the board. You should have 4 speeds to pick from you could take the black off of COOL and swap wires and test the unit by doing that. I'm going to put a solution on this so I can come back to it quicker. Even though we a just testing it for now. ken
Posted on Dec 21, 2008
motor1258
  • 6674 Answers
SOURCE: I have a comfort control 2200 thermostat. I
May be the location of the thermostat. Try another thermometer right beside wall thermostat & see what it reads.
Posted on Jul 19, 2009
SOURCE: I set my thermostat to 68 degrees. it stays there
set your progam modes to 0
Posted on Feb 02, 2010
Why does my Honeywell thermostat state temporarily set at 68 degrees? A few days later, it will be set at 62 degrees without anyone touching the thermostat?
It's a programmable thermostat. When you change the temperature, it will say temporary until the next programmed schedule starts or a set amount of time. You will have to program the thermostat to the correct temp settings you wish to have, or you can push "HOLD" after changing the temp to make it stay at that set point. Hope this helps!
Nov 19, 2016 | Heating & Cooling
Override thermostat temperature setting on ge rak1481d
To override the temperature limits, simply remove the thermostat cover, and then carefully replace it again, making sure the pins line up correctly. That's it! You can now set the thermostat as low as 60° and turn fan to "On."
Mar 16, 2013 | GE RAK147D1
Where do I set thermostat when temp is 10 degrees outside?
Setting a thermostat has nothing to do with outdoor temperature, but more to do with what is a comfortable setting for you and your utility bill.
A common misconception associated with thermostats is that a furnace works harder than normal to warm the space back to a comfortable temperature after the thermostat has been set back, resulting in little or no savings. This misconception has been dispelled by years of research and numerous studies. The fuel required to reheat a building to a comfortable temperature is roughly equal to the fuel saved as the building drops to the lower temperature. You save fuel between the time that the temperature stabilizes at the lower level and the next time heat is needed. So, the longer your house remains at the lower temperature, the more energy you save.
Another misconception is that the higher you raise a thermostat, the more heat the furnace will put out, or that the house will warm up faster if the thermostat is raised higher. Furnaces put out the same amount of heat no matter how high the thermostat is set; the variable is how long it must stay on to reach the set temperature.
In the winter, significant savings can be obtained by manually or automatically reducing your thermostat's temperature setting for as little as four hours per day. These savings can be attributed to a building's heat loss in the winter, which depends greatly on the difference between the inside and outside temperatures. For example, if you set the temperature back on your thermostat for an entire night, your energy savings will be substantial. By turning your thermostat back 10 to 15 degrees for 8 hours, you can save about 5 to 15 percent a year on your heating bill -- a savings of as much as 1 percent for each degree if the setback period is eight hours long.
Hope this helps..........
Nov 23, 2010 | Goodman GMS90703BXA Heater
I keep setting my thermostat but it automatically goes back to same temperature no matter what i set it at
If it is a programmable thermostat, it will only stay at a certain temp until it reaches it or on a set time, then it goes back to the scheduled program temperatures. Most programmable thermostats do have a hold feature that allows you to hold the temp to a certain setting, but if you don't set it to permanent hold, then it does what you described. Hopefully this helps some or guides you in the right direction. Good luck!
Mar 12, 2010 | Heating & Cooling
How do I set my thermostat for my furnace? My thermostat wont come on appropriately. I think I pushed wrong buttons and can't get the heat to stay on. Would like to cancel settings and be able to set...
Set the System switch to either Heat or Cool. Press the Hold Temp button. Use the Warmer/Cooler buttons to set temperature. Temps will stay until you either turn off the system switch or press Run Program.  Good luck.
Jan 02, 2010 | Honeywell CT3200 5-2 Day Electronic...
HONEYWELL CM921 ROOM THERMOSTAT
Remember the is a time and temperature controller if you want to use as an ON/OFF controller please ensure you OFF times are set to LOW temperatures for example at 8:00am I want the boiler firing to 21°C at 10:00 I want the boiler to go OFF at 5°C so ensure all so called OFF times are set to LOW temperatures.
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Heating & Cooling Logo
Top Proselect Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Proselect Heating and Cooling Expert? Answer questions, earn points and help others
