Question about Kenmore Progressive Canister Motor
Kenmore power-mate 116 57612690
Part number
2 Suggested Answers
VacuumRepair
  • 438 Answers
SOURCE: owners manual for kenmore power-mate # 116
Greetings from GoVacuum,
I wasn't able to find the manual for the Kenmore model, however I did find the instruction manual for the corresponding Panasonic canister vacuum cleaner. Your particular Kenmore model is actually made by Panasonic for Sears, and then Sears puts the Kenmore name on the vacuum cleaner. They are identical internally, and have the same parts and components, besides the filter that is behind the bag. Sears makes Panasonic put a specially designed filter in the Kenmore's so that the customer has to go back and purchase that filter from Sears.
To download the instruction manual, please visit the link below;
Owners Manual For Sears Kenmore Power-Mate Model 116.3489890C
You can also find a parts schematic of the power head below if you need to purchase parts;
Parts Schematic For Sears Kenmore Power-Mate Model 116.6489890C
I hope that this information helps you. Please let us know if we can provide you any further service, or if you have any further questions we can answer. You may email me at chris (dot) jones (at) govacuum.com.
If this helped you, please click the Helpful button below.
Chris Jones
GoVacuum.com
Posted on Mar 18, 2010
Testimonial: "Just what I was looking for ! "
Kenmore model 116 58015700 power mate beater bar stops working
Just pulled mine apart and the bearing on the belt side is toast. In the past five years I have had several items fail due to less then optimal bearings. Including a transmission in a Vibe and a front load washing machine.
Mar 30, 2013 | Kenmore Vacuums
Owners manual for kenmore power-mate # 116
Chris Jones
GoVacuum.com
Mar 18, 2010 | Kenmore Vacuums
I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Dec 29, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore vacuum model 25614 power mate will not reset
What you see from the outside is usually a pop up button which sits on top of the actual internal switch remove the lid of the power mate as though you are cleaning the brush roll or changing the belt. Then test the reset internally. Post back to advise .
Sep 19, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Canister motor not on - power to power mate is on
if its a long plastic tube with snaps on it that is where the fuse is.open it up and you will find the fuse
Apr 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister power-mate
I was able to get the whole thing reassembled.  If there is something specific that you are having trouble with let me know.  Everything snaps into its specific spot--it is just tricky to get it all lined up.
Sep 19, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Power mate jr
Did you push the reset? Check where the plug from the power head goes into the end of the handle. Sometmes the female plug gets pushed in to far, then the male part can't plug in and you will have no power to the power head. If this is the case, the the tabs on the tube inside the handle broke off and allowed the female plug to be pushed inside the handle. The other is the switch in the handle is bad, motor could also be bad. If you go to sears.com, click on the parts link, put in your complete model number and you will get a parts list and picture breakdown to look at and you can order parts here also.
Jun 22, 2008 | Kenmore 22812 Bagged Canister Vacuum
Kenmore whispertone model 11620412003
I am getting suction to the power mate, but the mate doesn't
work. The belt seem fine, but the light and beater doesen.t
go on. Tried the reset - no result. Thanks
Dec 29, 2007 | Vacuums
Kenmore Progressive 25614 vacuum
check the reset button on the brush assembly which is also called the power mate. if not then take it to your local sears repair center. if it is the pc board. sears has them in stock. I think it is about $7 for the part.
Dec 24, 2007 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore Progressive Canister Motor Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
