Question about RCA TruFlat 27F520T 27" TV
Tv has no sound. and will only come in on 1 channel.
  • bobetsky Nov 12, 2007
    retrace lines, poor brigtness
  • Anonymous Dec 16, 2007
    has pics but no sound
Retrace lines, poor brightness
Posted on Nov 12, 2007
We have a VIP 722 and the second channel is now without sound. We have sound on channel 1 but not 2. Any ideas?
Step 1: Check that TV or Stereo is not muted
Make sure that your TV or Stereo has not beed muted and that the volume is turned up loud enough to hear.
Step 2: Reset Receiver
If the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
Please note: It may take up to 5 minutes for the reset process to be completed.
Step 3: Check Receiver-to-TV Configuration
Check that the wiring between your DISH receiver and your TV is configured properly.
Step 4: Secure Receiver-to-TV Connections
Check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure.
Mar 10, 2011 | DISH Network ViP722 DTV Receiver /...
No picture or sound on some channels
we cannot get a picture or sound on several channels. Otherwise the TV works fine. Any solutions? as you get p&s on several channels so your ser is ok the problem 1 loose contact near tuner or it is defective. 2 tuner signal line .
Sep 16, 2007 | Toshiba 20AF44 20" TV
Hi my lg lcd model no 42LB9DE works fine apart from 1 tv channel has perfect pic but no sounds have re-tuned tv many times to no avail... any ideas ? Tv antenna is is proper working order only 1 channel i...
by reading your problem the main thing is that your tuner of the tv is faulty or it can not tune the specific frequancy of the channel and its audio frequency just replace your tuner card
Feb 16, 2011 | LG Televison & Video
Digital channel 25 has no sound.
First make sure SAP or nothing similar is turned on.
After you triple check that just Contact ILO if it continues for more than 1month. This is a software error.
What state are you in?
What channel is this?NBC, ABC
Have you check this at different times of day?
What TV does your son have?
Jun 24, 2009 | iLO 2600 Television
No sound on 1 channel
Check Your Audio Setting While On That Channel Access Your Tv Menu And Find Audio Change Between Sap Stereo And Mono Probably Will Fix It May Not.
Jan 05, 2009 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
RCA TruFlat  27F520T 27" TV Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
