Question about Hotpoint Hot Point - HTS17CBTWW Refrigeration : Refrigerator : Top Mount
Defrost not working - Hotpoint Hot Point - HTS17CBTWW Refrigeration : Refrigerator : Top Mount
Why doesn't automatic defrosting work?
There is a defrost timer that starts the defrost cycle. If the timer is not working you will have your situation.
Mar 11, 2016 | Refrigerators
Kenmore sidebyside 53552200 stoped cooling and defrosted completly light still works both frezer and refrigerator not getting cold
It could be stuck in defrost. Check your defrost heater, and see, if it is still hot. If it is, then the defrost timer is stuck. When it goes into defrost, everything, stops working, but the defrost heater and light. As long, as the defrost timer is on, nothing else will work, as far as the compressor, freezer fan, and any cooling/freezing.
Sep 07, 2014 | Kenmore Refrigerators
Freezer works but fridge does not
Lets see if the defrost timer being turned clockwise slowly will force defrost and cause things to get colder. On page 5 of the (click HERE=>ET4WSKXKQ02 Parts Manual ) you will see location 4? That is the 2188371 Defrost Timer
inside the fresh food com[partment at the top and behind the control panel will be the 2188371 Defrost Timer If forcing defrost solves the cooling problem then just replace the 2188371 Defrost Timer and if not we will need to check the 2176942 Defrost Heater Assembly and the 2192096 Defrost Thermostat Don't buy ba defrost thermostat until we discuss a different way of getting one to work should you need one (last resort because of cost) My focus is defrost timer and defrost heater at this point you will not need all the wires on the defrost thermostat should you need one just splice a simple defrost thermostat into the wiring harness. Below is a short movie on testing the defrost heater or click HERE Talk with me and we will get this refrigerator working, Sea Breeze
Refrigerator Defrost Heater Test
Refrigerator Defrost Thermostat Test
Apr 01, 2013 | Whirlpool Refrigerators
What is the difference between self defrost and cyclic defrost.
Hi, Self defrosting is auto defrost with out cycle. It work on controller leads. Cycle defrost timed defrost. It work after certain time The defrost work on evaporator
Jan 23, 2011 | Refrigerators
I INSTALL A DEFROST THERMOSTAT,THAT WERE BAD THE UNIT WORK FOUR DAYS AND STARTED FREEZING UP AGAIN,BY THE WAY THERMOSTAT IS GOOD. JIMMIE
is the fan motor working in freezer ? is the defrost element getting hot to defrost coil completley ?if they are working then the defrost thermostat may not be working correctly .its connected to the coil and has 2 wires, its round, clips on the coil..good luck this t-stat shuts off the defrost element; if coil is defrosted; before the timer finishes its defrost cycle
Aug 24, 2010 | Maytag Refrigerators
Refridgerator side not getting cold model gss201epaww
make sure the damper vent door located between the freezer and refrige compartments is opening and letting in cold air from the freezer,if they ice up they can stick shut and not allow air flow,this door is behind a plastic grille an a hair dryer works great to defrost them
Apr 30, 2010 | Refrigerators
Automatic defrost not working, but manual is?
Yes if the heater and defrost thermostat are good then the problem is the control board.
Sep 04, 2009 | Amana ARS266ZBS Side by Side Refrigerator
My Haier Mini Fridge comes on but keeps nothing cold. I defrosted in August and it worked for awhile and now it defrosted on its own and no longer gets cold.
This could be a bad defrost timer. See if the compressor is working. If it isn`t or only works sometimes. The defrost timer could be bad. When the frig goes into the defrost cycle, turns off the compressor. It may failing to turn the compressor back on after the defrost cycle. Since it stopped defrosting at one point and started again, the defrost timer may be bad. Let me know if this was any help or if I can help any farther.
Nov 12, 2008 | Haier Refrigerators
Jeep Liberty Defroster does not work when Idle
If you smell coolant, there probably is a leak somewhere.
Mar 11, 2017 | 2003 Jeep Liberty
My Bosch upright fridge is not defrosting & has a wall of ice on the back. The fan does not appear to be working either. Is that the problem? - cant remember how often I see the fan working now!Thanks
I kind of doubt that the fan is the problem. On my refrigerator, when it goes on defrost, the fan shuts off. They don't want it blowing heated air on the milk. Yours might be different.
I don't know this particular frig, but evidently the defroster doesn't work. Perhaps the fan doesn't work also, or perhaps the fan would work if the defroster were fixed.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
I think that when the defrost heater is turned on, then the fan is likewise turned off. The defrost thermostat, I think, is doing it's job, letting it cool again. But the timer is stuck. Or something???.
Hope you can fix it.
Aug 18, 2008 | Bosch Refrigerators
Hotpoint Hot Point - HTS17CBTWW Refrigeration : Refrigerator : Top Mount Logo
12 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
