Kenmore elite 42192
Smelly clothes
5 Suggested Answers
  • 163 Answers
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Posted on Mar 06, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 27, 2009
milten1
  • 1304 Answers
SOURCE: Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Posted on Oct 06, 2009
hunter19_46m
  • 7482 Answers
SOURCE: kenmore elite dryer runs but there is no heat, not drying clothes
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Posted on Oct 26, 2009
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
Smelly washer
To compare washer cleaners go to: http://www.youtube.com/watch?v=Ua6OJPn0-fU
To remove mold odor from your washer, towels and clothing safely and easily use Smelly Washer Cleaner. It advantages over others:
24 treatments compared to 1-3 for competitors.
It's completely natural.
The only washer cleaner available that also removes odor from towels and clothing.
It's cheaper! Even ordered from our website it's less than $0.71 per use!
Jun 10, 2010 | Kenmore 24902 Top Load Washer
We are fishermen and have trouble getting the smell and related fish residue off our clothes. have tried Nappysan; bleach; eucalyptus oil; and many other rpoducts. Any ideas? Dai
Hi.
I am not a professional fisherman, but I like fishing. For that reason when my clothes smell fish, that means that I caught a good prey, I am happy about the smell and throw the smelly clothes to my wife. I never thought about the problem.
However, after reading your question I had a look on the Internet, and I noticed you already tried the most popular solutions.
I found this thread , where poster are suggesting a number of remedies to get rid of the smell. Have a look. You will need to scroll down the page to find suggestions.
All the best.
G.
Oct 27, 2009 | Kenmore Elite 45986 Front Load Washer
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Clothes don't smell clean; how do I get my clothes to smell clean? Especially my towels.
Go to YouTube, type in "smelly washer".....really. You'll find several tutorials there; one of them is what you need.
Regards, --W/D--
Aug 01, 2009 | Kenmore Washing Machines
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
SMELLY WASHER
pouring .5 cups of bleach directly into the machine works great for me. I have tried other techniques, but they all failed. (I HIGHLY RECOMMEND WASHING A LOAD OF WHITES AFTER THIS JUST TO BE ON THE SAFE SIDE!)
Dec 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load HE washer odor
How old is your machine? Mine is 5 years old, and I just started to get a "sewage" smell in my laundry room this weekend. I disconnected the water return to the sewer line and discovered lots of gunk in the hose, and the connector to the machine was completely dark green. I'm going to replace the hose, and trying to figure out if there is some sort of filter.
We only use He detergents too, so I guess this is something that just happens over time.
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
Stinky clothes
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
