Question about Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave
How often should we change the microwave filter?
  • William Miller
    William Miller May 11, 2010
    Metal grease filters can be washed in hot soapy water, but charcoal filters cannot. They must be replaced.
    If you do mean the charcoal filter, replace them generally as often as is stated in the manual or whenever they're clogged.
    If you need more specific information, or help finding your manual online, please reply back with your brand and model number so we can help you.
It is a GE microwave that says reset filter
Open the microwave door and press the access panel above the cavity opening where it says "PUSH" to lower the panel door. Models with an Upfront Filter have a Reset Filter notification light on the control panel to indicate when it is time to change the filter. The Reset Filter reminder will light every 6 months.
Sep 16, 2017 | GE Microwave Ovens
How do I change the Charcoal filter on my GE microwave model # JVM1750WMC02
the charcoal filter is either in the top of the microwave or on the bottom, but you can order from APDEPOT.COM, Repairclinic.com or searspartsdirect.com
Feb 22, 2011 | GE JVM1750DM Microwave Oven
Need to clean upper filter, not bottom filter, does grille pop out?
Yes the grill pops out. It snaps in to place. Behind there is a Carbon Filter, and cannot be washed. The internet says the should be changed every 3 to 6 months, yet we use our microwave once a week and change mine every 9 months.
The carbon filter elimiates smoke, odors and grease build up on cabinets and walls.
We buy filters from HoodFilterFactory because they can make any size we need.
I hop this helps
Jan 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do I change the filter on the Hotpoint RVM1535WMCo01 microwave oven. When I took the top off I can not see a filter to replace. Does that mean that I have been running the Micro for the last year...
Microwave ovens produce dangerous emissions and require servicing by qualified technicians.
I suggest purchase a new one rather than repair because most microwave models cost as much to repair as simply buying a new one.
Nov 02, 2017 | GE Hotpoint RVM1535 Microwave Oven
Why double filter on Maytag Microwave
If your range hood or microwave recirculates back in to the room.
Both filters are required. The mesh filter catches the grease & air particulate. The carbon filter should be changed regularly www.HoodFilterFactory.com ( avoid range fires that spread quickly) & clears the recirculated air from smoke,odors, & airborne particulate.
With yours venting to the outside, you ONLY need the mesh filter. These filters should be cleaned regularly ( Avoid mentioned hazard) & should be replaced when you can no longer clean them enough to see through them when holding up to the light.
Good Luck
Apr 30, 2010 | Maytag MMV4205 Microwave Oven
Changing filter
The grease filter is changed from the bottom of the unit.
The charcoal filter is changed as follows:
To Remove Charcoal Filter
To remove the charcoal filter, disconnect power
at the main fuse or circuit breaker panel or
pull the plug.
Remove the top grille by removing the screws
that hold it in place and sliding the grille to the
left (opening the door makes grille removal
easier). Slide the filter towards the front of the
oven and remove it.
To Install Charcoal Filter
To install a new filter, remove plastic and other
outer wrapping from the new filter.
Insert the filter into the top opening of the oven as
shown. It will rest at an angle on 2 side support tabs
and in front of the right rear tab. Replace the grille
and screws.
Aug 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the charcoal filter?
There is no charcoal filter unless you replaced the standard filter with a carcoal filter. Also, it may have m=been changed to a charcoal filter if the unit was alterd during installation as a re-circulating vent, not vented to the outside via the roof or wall.
The filter (Charcoal or not) is on the bottom of the unit. Put your head under the microwave and look up, there it is.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need service manuals for amana HDC12 & HDC12A2 microwaves
Unit says change filter and do not Know what that is talking about? Also need to Know how to clear change filter off of screen?
Mar 17, 2009 | Amana HDC12 Microwave Oven
Wrong Grease Filter for Sharp R-1870 Microwave
I also have a Sharp over the Range Microwave oven that requires a charcoal filter. But my diagram shows that the charcoal filter goes behind the slotted panel at the top of the microwave. To reach the filter, you must remove a screw on the top edge of the microwave. This allows the panel to come off. Your charcoal filter goes there. Since your oven is new, you do not need to change this filter yet because it's not dirty. I would save it for future use.
According to my book, there are two kinds of filters with this oven. The charcoal filter is the one behind the front panel. The Grease filters ARE the two metal mesh ones. They can be cleaned with hot soapy water, or I put mine in the dishwasher.
Mar 14, 2009 | Sharp R-1480 Microwave Oven
Jenn-Air Microwave Bulb and Filters Inaccessible - Design Flaw - Help!
It's not a design flaw. The microwave was incorrectly mounted.
The installation instructions (installation kit) included a template for proper alignment of the microwave on the cabinetry.
If it had been aligned with the template, the two top grill screws would be easily accessible.
The grille must be removed to access the lights and the charcoal filters, which should be changed every 6-12 months if they are used.
If they are in place and not changed regularly, critical ventilation and cooling can be affected.
Your owner's manual can be downloaded free here, and it shows you how to change the bulbs and filter.
It will have to be remounted properly.
Nov 06, 2008 | Jenn-Air Microwave Ovens
Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave Logo
1,139 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
