Question about Maytag MSD2756G Side by Side Refrigerator
Actuator sticks water actuator pad sticks
Actuator not getting vacuum
look for a leaking vacuum hose or one tat is no longer connected to the engine intake manifold.
Apr 02, 2015 | Cars & Trucks
I had macaroni stick in one of my pots, how do I get it clean. It's blk inside the pot,
To remove stuck on food use water (the world's strongest universal solvent). But add a degreaser. Degreasers change the surface tension of water molecules to make the water droplets much smaller. Once they are smaller they can get into areas to start dissolving what it could not approach previously. Detergent being a surfactant also allows mixing oils and water. Hot soapy water works better. We used to use boiling water in a chinese restaurant i used to work at. Boiling water helps alot. Since your food is charred it is more likely carbon sticking to the non-stick surface. Your non-stick surface must not be non-stick anymore due to using the wrong chemicals or pads on it. High temperatures make silicone type non-stick coatings fail too. If there is no more non-stick coating to worry about you could use an oven cleaner. Oven cleaners are made of caustic soda or lye. Lye is made from common table salt (sodium chloride) Oven cleaner is great at attacking carbon but not very friendly to aluminums or the finished paint on any metals on appliances. Use your own discretion.
Mar 21, 2013 | Cook's Essentials CooksEssentials 3 Quart...
The ice and water dispenser gets "stuck" in the
Hello, Thank You for using FixYa. I will be helping you today. You need to replace the Pad, Actuator (blk) Part #: 61003804 It is a common issue with this unit. And if you do it yourself greese the white plastic part on the back of the pad.
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Maytag MZD2766GES Side by Side...
PLEASE TELL ME WHAT DOES A MASTERCOOL CLEAN MACHINE PURGE PUMP DO?
From the ad below, it replaces old water with fresh. ------------------------------------------------------------------------- » HVACR» Air Conditioners» Evaporative Cooler Accessories Universal Cooler Cleaning SystemBrand: MastercoolModel: CM120ASKU: 47495 34252_300.jpg
$74.13
3 Business Day Shipping $7.91
No Longer Available Mastercool CM120A Universal Cooler Cleaning SystemTotal Ratings: 0
Average Rating: 0
Review this item transparent.gif Product Information Item Cleaning System Function Timer-actuated, Automatically Removes Mineral-laden, Dirty Water every Six Hours and Replaces with Fresh Water, Reduces Scale Deposits and Leaves Pads Cleaner, Saves Up to 70 Percentage of the Water Weight 3.10
  • Replacement Motors and Accessories
  • Universal Cooler Accessories
  • Cleaning System
  • Save up to 70% of the water used in bleed-off cleaning systems.
  • Timer-actuated drain system automatically removes mineral-laden, dirty water every six hours and replaces with fresh water.
  • Reduces scale deposits and leaves pads cleaner.
  • Uses: For residential size coolers only.
  • Note: Limited availability.
Universal Cooler Cleaning System, Clean Machine Pump Cooler Flushing Device for Residential Size Coolers Only
Apr 04, 2011 | Heating & Cooling
ADF is starting the page scan about 1/2 inch above the top of the page
Pop open the cover and clean the rollers with alcohol. Your feed pad could be worn out also. Make sure the feed switch actuator is not sticking.
Jan 05, 2010 | Fujitsu fi-4340C Flatbed Scanner
For some reason the dispenser will stop working part of the time and more recently will stick on and overflow.I pulled the cover off the inside of the door and there is ice buitl up on the insulation.
You need to thaw out the ice machine and see if it works after you thaw it out if that does not fix the problem then the control arm for the ice dispenser is bent.
Nov 22, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
I have the maytag side-by-side model MZD2725GRW.The actuator pad sticks and water and ice will not stop unless the door is opened.Where can i get the part to fix this?
Call Maytag Direct for parts. Give them the model number. Alternatively, look up a local appliance supply store and visit them with your information. Many times they have suppliers if Maytag no longer makes the parts.
Aug 20, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice dispenser won't stop dispensing
The rubber piece you put your container against , has a little plastic "trigger" attached . Usually they tend to stick . The dispensor has to be disasembled to replace the rubber actuator . Sometimes I've found using a small amount of white grease on the plastic piece fixes the problem without replacing the rubber pad .
Jul 17, 2009 | Maytag MCD2257H Side by Side Refrigerator
Water continousily comes out of water dispensor
u need to replace your microswitch and probably the pad depending on make and model
Mar 18, 2009 | Refrigerators
ACTUATER PAD
Yes sounds like you need a new actuator pad. I had one do this this week and a new pad resolved it.
Dec 07, 2007 | Maytag MSD2432G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
