Gas fire keeps going out
Gas seems to cut out
Mower cutting out
be sure vent is clean in gas cap
Sep 25, 2013 | Garden
Excaliber ght180 cuts out
Rebuild carburetor or find part number for carburetor and go online some carbs. Are cheaper to buy than rebuild.
Sep 13, 2017 | Garden
Make = Trident exel natural flame gas fire - model fan powered rear flue - 549 RMN FEF +3 The fire ignites and runs normally for about 10 minutes and then the gas side completely cuts out (both the...
Hi this is a oxy pilot problem as you say, would be best to replace. There are two types that were used on Trident /FEF fires,Ican help with either but need to know which one ,get back to me for further help .Will.
Nov 11, 2010 | Heating & Cooling
My rinnai gas log fire cuts out after 8-10 seconds when turned on,& the number 12 flashes on the displey
Fault code 12 means the flame lit ok but hen for some reason went out. In my experience this usually means a fault on the gas supply itself. If you are on lpg I have had many problems with gas regulators recently. If you have something else on gas like a cooktop, fire that up first, then try the log fire. If this seems to fix the fault get a gas fitter to change the regulator.
Make sure all taps and isolattion valves are fully on.
I'm have assumed this is not a new installation so the unit has worked ok before.
Does the flame stay strong after it lights. If it slowly fades then definately a gas supply problem.
If it stays strong but just shuts of with a click, then possibly a fault on the heater, check the rod the flame heats is well in the flame. Could be the electronic otherwise but very rare.
If the flame goes yellow like a candle and then shuts off you will need to check the flue or chimmney as this might be blocked..
Cheers, let me know if anything works and re-post with any more info if you are still stuck, I will keep a look out for you.
Aug 08, 2010 | Heating & Cooling
My Rheem furnace fires up but the fire keeps cutting
Hi check out the pressure switch ,jump it out see if it fires clean flame senser if fitted, clean airfilter check fan afc is clean might be dusty
Feb 02, 2010 | Heating & Cooling
Hooked up gas stove and fire want go out when cut off.
NO - the fire is supposed to go out! Your gas valve is bad and if you'll give us a call asap, we'll make sure you get the correct part to replace. Call us at 972-859-0929 and let us ship this part to you. We look forward to working with you! Have a great day!
Oct 03, 2009 | GE JGRS14 Gas Single Oven
Laundrette dryer producing no heat
Change out the igniter
Diamond Service
Apr 02, 2009 | LG DLE7177 Dryer
Gas supply keeps cutting out
I'd be checking what the operating gas pressure is correct - when it's operating, not when it's stopped or off. My suspicion is that the gas pressure is incorrect & the regulator needs adjusting, or that the gas bottle is simply too small for the heater & can't evaporate enough gas to keep it going. You really need a gas expert to advise on site. Regards, Greg (Aussie gasfitter - too far to do house calls)
Sep 03, 2007 | DeLonghi IHF2 Heater
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
