Question about GE AJCQ08ACB Air Conditioner
A/C spits out ice
Wall a/c unit clicks sometimes, loudly, and tonight, it spit out a spray of ice chunks.
  • 23 Answers
You probably have a plugged filter and or a dirty evaporator. pull the filter and see if it is dirty. it should be lockated right behind the front panel. The evaporator is right behind it. If they are both clean then the unit is low on refrigerant most likely. if it is low it is probably more worth wile to by a new window unit then having a service man out.
Posted on Jun 15, 2009
Whirlpool fridge freezer no water getting through to icemaker
Check the line going from the back of the fridge through the freezer wall. Sometimes you can get a chunk of ice in the line. Also, did you check to make sure the solenoid valve works? Disconnect the solenoid valve outlet and when there is a demand for water, it should click and water should flow
Jan 14, 2018 | Whirlpool Refrigerators
Shoots drips
Most airless spray guns spit a bit when you pull or release the trigger because the paint between the spray tip and the paint valve is under pressure but not enough to atomise the paint. If you increase the pressure you may reduce the spit to a point when you don't notice it. A blocked filter could slow the paint getting through to the tip cause lower pressure.
Jan 03, 2014 | Wagner SprayTech Wagner Airless Paint...
I have an old Frigidaire refrigeator/freezer, freezer on top. Model # FRT18TJHWO. It say manufactured 06-00. I presume that means June of 2000. I have had this for almost two years. A friend gave it...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 21, 2010 | Frigidaire Refrigerators
Ice coming from unit?? WHy would ice be "spitting" from front indoor wall unit
The unit has frozen up, and the fan is blowing out small particles of ice.
Freeze up is due to Improper airflow, and/or low refrigerant charge.
In the case of a heatpump, it can also be due to a malfunctioning defrost cycle.
Most likely, the filter and/or coils are dirty, causing an air restriction. I'd reccoment cleaning both coils and the filter. Let the system defrost, and run it again. If the problem persists, you have a refrigerant problem.
(or a defrost issue with a wall mount heat pump.)
Feb 07, 2010 | Heating & Cooling
Lsc26905tt = chunks of styrofoam coming from ice maker
Over the past few years the appliance companies have found that it is less costly and more efficient to replace the traditional spray in foam insulation to Styrofoam panels. They do sometimes shift. When they shift they can come in contact with the fan. The blade shaves them and then blows the foam particles into the unit. If you are comfortable with doing repairs then you can fix this. You will need to un-plug the refrigerator and remove everything in the freezer. You will see a series of screws in the back inside panel. Take these screws out and remove the panel. You will expose the coil and fan assembly. Inspect it and make any adjustments to the foam at this time. assemble in reverse. Hope this helps. Good luck. RE-post with updates. Thanks cj2176.
Jul 09, 2009 | LG LSC26905TT Side by Side Refrigerator
Wall-mounted air conditioners freezing and spitting ice.
if they are freezing up and only 2 months old there is probably a lack of air flow look in the manuals for maintenace and clean the air filter
Jul 08, 2009 | Heating & Cooling
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridigaire side by side ice maker not dispensing
The auger does not have the strength to do it's job when a lot of ice is in the way. You can defrost the icemaker with a blow dryer. It will be messy so be ready with lots of towels or a mop.
Once the unit is dry, spray the auger with PAM or some similar cooking spray. Then let it recycle.
You can temporarily prevent more fresh water from entering the ice maker by simply moving the wire arm to the up position
Jan 31, 2009 | Frigidaire FRS26R4A Side by Side...
Moldy water dispenser area
If you go to geappliances.com click on service and support then click on use and care manuals you can download a use and care manual. Since the refrigerator is white I'd probably use a good bleach spray on the mold be sure to rinse well though so you don't end up ingesting bleach. Chunk of ice sounds like too much water or not enough cold and a qualified tech might not be a bad idea. Good Luck.
Jan 01, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice chunks
freeon problem or dirty filter
May 24, 2007 | Goldstar R1003 Air Conditioner
GE AJCQ08ACB Air Conditioner Logo
2,488 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
