Question about Audio Technica Televison & Video
Some buttons on remote control does not work
Mute button &blue button on remote control does not work
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Time to buy new remote
Posted on Sep 05, 2014
RCA fios remote a/v button mutes TV instead of switching inputs. Mute button does nothing
Remote control damaged. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Mar 26, 2014 | RCA Televison & Video
I need remote codes for vizio vbr231 blue ray player as well as a teac home theater receiver AG D9260
We don't have codes for the Vizion Blue-Ray player but I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 06, 2011 | DISH Network IR Remote Control
I want to know if the Directv Universal remote control can be use for the Insginia Blue Ray Player.
Setup Instructions
  • Set the "Mode Switch" to Device 2.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • Aug 23, 2010 | Universal Remote Control DIRECTV Universal...
    I have an HD remote control and the mute button doesn't work. Can I program it to do so?
    When your all other buttons work only the mute button doesnt work.The problem lies with the mute button only.Not with programming.
    Thanx
    Jul 31, 2010 | RCA DIRECTV Satellite Remote Control
    Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
    Could be a contact piece of the MUTE button from your remote that is causing it.
    Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
    However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
    solutiondoct
    Nov 10, 2008 | Toshiba Televison & Video
    Convergence
    Replaced convergance power packs (2) stk392-110 check all 2watt resistor the packs, to enter the convergance alinment mode on the set. Using the remote control press and release the sleep timer button when sleep timer displays timer equals zero immediately press the display and V. status buttons at the same time.  If done quickly enough the service menu will appear once entered the careful not to does disturb or change any other settings press the number seven to enter the convergence alignment mode a full crosshair pattern will appear in this alignment mode you can adjust the blue and the red to line them on the green using the select and the number pad you can move to the next crosshair to align the boot to the green and then the red to the green when done pressing the muting button on the remote control will save your changes will take a little while to figure this out as you work with.  If you make an unwanted error pressing exit without hitting the muting button will restore your convergence to its previous  setting.  If you're green is off after entering the service mode press the number six on your remote control in this setting will be able to adjust the green only once that is done us the muting button.  Then enter button seven if need be to adjust the blue and the red.  Remember no changes have been stored until the muting button is pushed open this helps.
    Oct 14, 2007 | JVC AV-48WP30 48" Rear Projection...
    Samsung TV remote control
    I HAVE THE SOLUTION TO THIS PROBLEM.
    Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
    Sep 28, 2007 | Samsung TV Remote Control
    Resetting the parental control password?
    try master pass 3308 Childlock The CHlLDLOCK function prevents chiIdren from watching TV. HoId down the F button and then press the MUTE button until the symboI ? ? appears on the screen, and the TV enters the CHlLDLOCK mode. Except for the symboI? ?, the screen becomes blue back and mutes when you press the buton to turn the TV off, then turn the TV on after setting the CHILDLOCK function. To unlock the TV, hoId down the F button and then press the MUTE button again. Note: The CHlLDLOCK can be set or cancelIed only by the remote controI. After setting CHlLDLOCK, secure the remote control in a safe place
    Aug 14, 2007 | Apex Digital AT1314DV 13 in. TV/DVD Combo
    Televison & Video Logo
    37 people viewed this question
    Top Audio Technica Televison & Video Experts
    Lawrence Oravetz
    Gil Shultz
    ray gallant
    Are you an Audio Technica Televison and Video Expert? Answer questions, earn points and help others
