Question about Pioneer DEQ-7600 15-Band Car Equalizer
All the buttons light still on after car shut off
All the buttons light still on after shut off the car.lock the door .....i sure the cd receiver is off.is it normal?if not could someone plzzz help me out.
  • 578 Answers
One of your power source wire is connect wrong and giving power when vehicle is off check your power source wiring
Posted on Jul 07, 2009
How i cut my lights off in my car doors when the car is turned off
when the car is not running and all the doors are shut the lights should turn of due to a pin switch being pressed in the door apature or lock mec some int lights work of a relay which means there might be a short delay before the go out
Feb 23, 2011 | 2001 Buick LeSabre
Isuzu trooper 2001 battery replaced and key fob does not work with door locks but responds with 5 beeps when lock button is pushed. What might be the problem here. Thanks RJ
possibly it still thinks a door is open check out rear cargo door switch this is usually the culprit because its seperate from the rest of the doors. turn on rear cargo light to doors ,make sure it works then shut rear cargo door and see if light is still on. if light is still on theres your problem.
look at switch usually they get dammaged/distorted over time.
Feb 21, 2011 | 2001 Isuzu Trooper
95 chevy blazer 4 door. driver door started to sagg slightly, shortly after the interior light wont go off without pulling the fuse. then the power door locks wont work. Ive heard when door is shut it must...
with the door sagging it may not be pushing button in far enough to shut light off or aligning with button right.Replace bushings in door.The fuse is probably the same one for light and door locks.
Sep 18, 2017 | 1995 Chevrolet Blazer
Door ajar light on, dome light stays on. now the car alarm is sounding if car is locked
check the jamb of the doors,there should be a little black sensor that looks like a push button,that is the only way the vehicle know whether the door is opened or closed,In some cases if something is shut in there it will push it back into the body where it dosent get contact with the door and the comuter will sense the door is not shut. if the problem is not visible you may have to go around one by one and hold it in by hand until the lights go off or in your case dont go off.make sure all other doors are shut besides the one you are working on at the time.you may have to hold them in any where from 30 seconds to 2 minutes
Jan 09, 2011 | 2002 Ford Explorer
I have a 98 GMC JIMMY. Remotes and Dome Lights stopped working. Car would start then immediately die. Took it to the dealer and they stated it was the Body Control Modual (BMC). Picked up the vehicle...
Keyless Entry System Circuit Description
The Power Door Locks/Remote Keyless Entry control system provides several functions. The driver operates the vehicle door locks and rear window release from outside the vehicle using a hand-held radio transmitter. The transmitter sends coded signals to the remote control door lock receiver. The remote control door lock receiver detects and decodes the signal from the transmitter. The remote control door lock receiver issues signals to the body control module (BCM) through a serial data link. The BCM actuates relays to lock and unlock the doors and liftgate. The BCM can also release the liftglass. The power door lock switches provide manual control of the door locks.
Transmitter Programming
Important: Different keyless entry systems are used on General Motors vehicles. The parts are not interchangeable even though the parts may appear to be similar. Observe the back of the transmitter in order to properly identify the system. On 1998 S/T pickups and utilities, use a transmitter identified with GM/UTA preceding the part number.
With the driver door closed, hold down the power unlock button on the door panel.
Turn the ignition switch to the ON position.
Turn the ignition switch to the OFF position.
Release the power unlock button on the door panel.
The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode:
6.1. Locking the doors
6.2. Unlocking the doors
Important: All extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner:
7.1. Locking the doors.
7.2. Unlocking the doors.
Repeat step 7 for each additional transmitter.
Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
May 04, 2017 | 1998 GMC Jimmy
I got my remote starter to work when i first got the car but now i can't get it to work what am i doing wrong?looked in the manual and turned the key on like it said to do but it still does not start with...
If the remote start is GM, Start the car, shut it off, Get out, lock the doors, Wait for the front end lights to go out, press the lock button, press the start button. The engine should start.
Dec 06, 2009 | 2009 Chevrolet Cobalt
Coding a key for a renault laguna
Renault Laguna II Key Remote Control Programming
LAGUNA II INFRA RED RESYNCHRONISING
1. Turn the Ignition OFF.
2. Press the central door locking button for more than 5 seconds. Note: the door should lock then unlock.
3. When this happens 15 seconds is allowed and the immobiliser warning light illuminates.
4. Point the 1st key at the receiver and press the button once, the doors should lock and unlock.
5. Point the 2nd key at the receiver and press the button once, the doors should lock and unlock.
6. Check the remote control unlocks and locks the doors.
Mar 24, 2009 | 2004 Renault 181
The security on my 1993 Grand Cherokee will not turn off
I may be able to help if you havent fixed it yet. I believe I had the same/similiar issue...
I would make sure all of the doors were locked with auto lock button on inside of door, then I would shut the door so all doors were locked from pressing the inside auto lock button. then I would use my key to unlock the trunk, open the trunk and close it leaving it unlocked. then i would use the key to unlock the drivers door and the security would reset... if not then unhook the battery for a few minutes then hook back up and see if that works.. glgl
Mar 10, 2009 | 1993 Jeep Grand Cherokee
The alarm form my car is ringing with no reason at all....it is very anoiyng for everybody.would u know why? how can i fix this? i can/t even disconected coz i dont know where is it....i just disconect the...
Mine is the same, so I lock mine manually, using the rocker switch on the drivers door. Set all of the other switches to lock (use the power lock button) then open the drivers door to get out and before closing the door flick the rocker switch on the door to lock and shut the door. This makes sure the doors are locked but disables the alarm. You will notice that the red flashing light on the dash which lets you know that the alarm is engaged will not be flashing, the alarm is disengaged. Much easier than disconnecting the battery...
Read the manual to identify the power lock button from the manual door lock switch.
Nov 10, 2008 | 2006 Chrysler Neon
2002 Honda Odyssey security alarm system
Make sure your hood is shut. I just got my 2002 Honda Odyssey back from the dealer today (90,000 mile check-up - I love my van and will drive it until it dies!) and when I went to lock the van with my remote transmitter, the lights didn't flash and the horn didn't sound. I open and closed all the doors and tailgate and I could hear that the doors were locked, but the security system wasn't working and that is why the lights didn't blink or the horn didn't sound. I walked up to the front of the van to check the hood to make sure it was closed (there isn't an indicator light for an open hood, only open doors) and the hood wasn't shut completely. Once I opened the hood and let it drop to securely shut, I hit the door lock button on the remote and everything worked like a charm! Hope this helps others in this predicament.
Sep 12, 2008 | 2002 Honda Odyssey
Pioneer DEQ-7600 15-Band Car Equalizer Logo
104 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
