Question about Conair Compact Fabric Steamer GS4
Cannot open gs4
Internet directions read "take cap off hose." Is this correct? Cannot seem to open.
How do I fill the GS4 steamer?
http://www.conair.com/instruction_booklets/10pa117459_gsS4_ib%5B1%5D.pdf
Oct 19, 2014 | Conair Compact Fabric Steamer GS4
Rowenta 1500 garmet steamer no longer makes steam
Someone else had this fix and it worked for me: (yay!)
*Remove water tank and collapse the hanger bar.
*Remove two screws at base of hose and work the hose off. It will come out.
*Unplug unit and hold over your kitchen sink with the hose inlet pointing into the sink.
* use your kitchen sink sprayer to forcefully spray water into this hole and it will come back out again releasing the gunk that has been stopping up the unit.
* for good measure, I also used the sink sprayer to flush out the hose.
Put everything back together. And make sure it is dry before you plug it in.
VOILA!!! WORKS GOOD AS NEW. HAPPINESS!
Jan 10, 2014 | Conair Gs4 Iron
Re Conair garment steamer ctx12c
I bought this model from Costco and followed the instructions and tried using the picture on the box. You may have trouble, or at least be confused, if you try to attach like the picture on the package because the hose in the box is not exactly as pictured.  The hose you get does not have that extra ribbed part around the end that attaches to the console.  Therefore try the other end and you should be able to attach.  Once you figure that out make sure you "lock" the hose into place.  If not steam will escape from the loose installation and may scald you if you reach down.
Oct 06, 2008 | Conair Compact Garment Steamer Iron
When using steam iron i am left with a puddle of water on the floor how do i control the amount of steam
I think is maybe the hose connections. You need to make sure both ends (by the T-nozzle and by the body of the steamer) are secure. You have to align the nozzle with the rod, and push down, and twist. Try watching instructions for connecting both ends on www.HandBookLive.com under appliances category. There are GS4 video instructions and GS10 (this one has just been posted yesterday)
hoe it helps. Otherwise I would return the steamer. Nowhere in the operating instructions does it say that you can control the amount of stream produced...
Laura
Sep 27, 2008 | Conair Compact Garment Steamer Iron
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Sep 03, 2008 | Conair Compact Garment Steamer Iron
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Conair steam cleaner sc20 - plugged in, pushed button, no steam
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
Apr 15, 2008 | Conair Compact Garment Steamer Iron
Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Oct 28, 2007 | Conair Gs4 Iron
Conair Compact Fabric Steamer GS4 Logo
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
