Question about HP LaserJet 4mv Printer
Hp 4mv paper jam
    Novelist:
  • HP Expert
  • 297 Answers
You probably need to replace the paper feed rollers, which are no longer available from HP...
Posted on Jun 06, 2014
3 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Posted on Dec 15, 2008
  • 14 Answers
SOURCE: HP LaserJet 4MV
You could remove the fuser, turn the machine off, and wait an hour. It may reset the error. However, if the error still persists, it will be a parts replacement of the fuser, low voltage power supply, or the DC controller. 90% it is the fuser. Good luck.
Posted on Apr 23, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
4mv won't pick up paper
The feed rollers need to be replaced. The squeak is the worn rollers sliding over the edge of the paper.
Mar 25, 2014 | HP LaserJet 4mv Printer
HP LaserJet 4MV '50 service' on an HP LaserJet 4MV printer Can it be cleared without resorting to repairs or replacement parts?
Apr 21, 2010 | HP Office Equipment & Supplies
Hp 4mv printer paper jam
take out the cable and then press the power button for 1 min
Feb 11, 2010 | Office Equipment & Supplies
Paper jam in HP Laserjet 4V
remove the cassette you can see two or 3 roller down the printer clean that roller and try.....
Oct 07, 2009 | HP LaserJet 4mv Printer
Feeds ok from tray 1 but not tray 2 which is 11x17. There are slight buffed marks at on the papaer in 4 spots but paper wont advance. marks are about 1/4 inch long
those marks are the rollers trying to move the paper. check to see if your tray 2 is lifting.if it is then replace the feed rollers.
Sep 28, 2009 | HP LaserJet 4mv Printer
HP 4MV Printr and ip address
Scroll through the menus until you get to the I/O section. I don't think vista supports the HP 4MV
Mar 12, 2009 | HP LaserJet 4mv Printer
Repair Kit for HP 4MV Printer - Pick Up Rollers
The ruber tyres on the pick rollers can harden with age, even if you are not using it. Try applying gum turpentine to rubber tyre with Q tip. This is used to keep a printer picking up untill replacemant rollers can be fitted.
Dec 15, 2008 | HP LaserJet 1020 Printer
Good old 4MV.
Dec 15, 2008 | HP LaserJet 4mv Printer
Paper Jam
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Sep 16, 2008 | HP LaserJet 4mv Printer
HP LaserJet 4mv Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
