Question about Kitchen Ranges
Whirlpool wdp86804 range element
Whirlpool Range #RF114PXSB , both bake and broiler elements won't go on
If the burners have the same problem check your power, it sounds like one of the phases is out. There is a common wire to both units, it is aparently open.
Aug 24, 2014 | Whirlpool RF114PXSB 30-in Electric Range
Whirlpool Gold Range GJP 852400 LF dual element does not work
It is telling you that you have a problem with that element. Just like a "check engine" light in your car, it won't go off untill problem is fixed. Buy, and install a new element, easy to put in
Apr 07, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
I need to replace heating element. where do i
www.partselect.com/Whirlpool-Range-Parts.htm - 4 hours ago
www.repairclinic.com › Whirlpool - 15 hours ago
Apr 04, 2010 | Whirlpool RF368LXKS Electric Kitchen Range
The electric burner elements on my whirlpool Super Capacity 365 stove often won't heat. They seem corroded on one tip and the socket they go into looks dark. Can I simply replace them?
YES YOU CAN . FIRST TURN OFF THE POWER TO RANGE , THEN LOCATE THE SCREWS ALONG THE SIDES OF THE TOP REMOVE AND YOU SHOULD BE ABLE TO SEE THE ELEMENTS AT THE END OF EACH ONE THERE IS A TWO PRONGED CONNECTION REMOVE ELEMENTS FROM THESE PULL OUT TAKE ALL THE ELEMENTS TO AN ELECTRICAL AND PLUMMERS SUPPYLY STORE FOR REPLACEMENTS, REFIT NEW ELEMENTS AND YOUR COOKER SHOULD WORK FINE , GOOD COOKING .
Nov 17, 2009 | Whirlpool RF364 Electric Kitchen Range
Broiler element stays on. I had to trip the
a wire in the back of your stove is grounded... open rear panel after unplugging and look for burnt wires going to the element. the wires will be a higher grade than most..
most likely there is no problem with the broil element itself, but the problem could possibly be located in the oven switch (if it is not digital)
Oct 09, 2009 | Whirlpool Kitchen Ranges
Bottom element needs replacing
the side right side panel comes off three screws hod it on the back pullout
Jan 17, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
How do I change the element on a Whirlpool Gold range?
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Sep 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
