Question about Whirlpool Refrigerators
Wirlpool model ET1FHTXMQ0 4 TEMP DROPPING
FOOD STARTING TO GO SOUR FASTER
I have a FF82 model and it is starting to freeze food. there is some frozen water in the bottom. The temp control dial doesnt move. What shoudl I do to fix this.
Temp dial shouldn't have a setting that would freeze your refrigerator side products anyway. Make sure damper to fridge isn't stuck or frozen which cuts off air from freezer to fridge when temp is achieved. If all working properly for sure. Sounds like bad temp control.
Oct 25, 2016 | Refrigerators
Freezer will not hold at freezer temprature 18degrees is dropping is currently at 6 degrees
Any Freezer does not stay at any one temp. If you freezer is part of your refrigerator then it goes through defrost and the temp will rise. When the compressor comes back on it will drop. How much food you have in your freezer will also be a factor. Not much food and the unit will flex widely in temp. too much food and the fan can not blow the coll air around properly and msy cause it to warm up. If you need more help please add additional information being very specific.
Mar 27, 2016 | Refrigerators
I have an amanarefrigerator freezer that is emitting a horrible sour smellHave done everything I know how pleasetellme what could be wrong
Rotten Food Particles--Soured Dairy Products--2 of many--will have to be taken apart to be checked.
Feb 27, 2015 | Refrigerators
Our Kenmore 253.28432801 is just over 5 years old. It stopped freezing, and the Sears tech says it has a leak and needs coils and a condenser. This would be $618, he suggested we buy a new freezer. Co
If it's holding at 28 degrees, it's not the coils. See if dropping the temp does any thing to lower the temp. If it does, fine. If not, most likely just the control needs replaced or just cleaned.
Nov 15, 2014 | Kenmore Freezers
Hello, I cleaned the refregerator ( not freezer) faster..so the door was open a several time but not for long time (didn't turn it off).After a few hours I noticed the refrigerator and the freezer...
Hi Tania,
This could be that the freezer is on a defrost cycle. Let it go overnight and see if you have temp in the morning. Let me know what happens so I can find out more if no relief.
Joe
Sep 07, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Our fridge is freezing , we reset the temp and it keeps on dropping and the water dispenser is also frozen
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Aug 29, 2011 | Kenmore Refrigerators
My Sub Zero 550 model seems like it is running all the time. It is too cold in the refrigerator compartment,and the condenser fan runs constantly. Adjusting down the temp control has no effect. Freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 15, 2010 | Sub-Zero 650 / O Bottom Freezer...
My freezer has dropped in temp to -6 and my refrigerator is rising in temp and only blowing minimal cool air. The fridge is less than one month old.
ck the back of the freezer / look for ice build up / if evap coil is blocked the fresh food side isnot getting cold air and the tempt of freezer is dropping . is sounds like a defrost problem caused by main board failure or heater / defrost themo . / fresh food will keep getting warmer and soon the freezer will also .. mm
Oct 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ambet temprature inside fridge when set on 1C
I can't help but wonder if the light is staying on... :)
It certainly sounds like a door seal, but did they replace the thermostat, or is that what you mean when you say sensor?
Sep 06, 2008 | Samsung Refrigerators
Refrigerators Logo
29 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
