Question about Stairmaster Stepmill 7000 Pt
It goes to fast
We tray to use but goes to fast
  • Stairmaster Master
  • 914 Answers
Phaser 7400 bypass feeder feeding cardstock much too fast
You need to make sure you set the proper paper type for the tray you are using. (Plain Paper feeds much faster than card stock)
Also recommend you use the bypass tray and open the rear door so the cardstock goes straight out the back of the machine and not delivered to the top.
Nov 09, 2013 | Xerox Phaser 7400DN Laser Printer
Were the water goes into the inlet inlet tray for the detergent and bleach the water is not going into the drum fast enough and it is gushing out from underneath the tray, is there maybe a easy fix.
the hose to the tub is blocked . If nothing in the dispenser end then you must remove the door boot (Seal)from the front pane and check the lower part of the hose. You can remove the top and the dispenser and get at it from there also.
Nov 23, 2010 | Whirlpool WFW8300S
Stuck DVD tray
Turn off the computer and then use the paper clip to open the DVD tray.
If this doesn't work, then something is jaming and stopping the tray from opening. In this case, remove the DVD drive and dismantle the drive (ie. remove the metal cover to reveal the internal components and remove the CD ot DVD disc.
If nothing works the the DVD drive is faulty and needs to be replaced, these drives are not expensive.
Jul 21, 2009 | HP Pavilion DV5234US Notebook Laptop
Not making ice fast enough in ice tray
the bar should be all way down it shouldnt be under tray
Feb 08, 2009 | Hotpoint HSS25GFP Side by Side...
Clogged drain..no water in tray
Take the back panel off inside your freezer and locate the opening of the drain. You will see the collection tray just under your coils and in the middle you will see the opening. Now if it is blocked by ice just take a couple tea spoons of table salt and pour on the opening. Ice will melt very fast and then the opening will clear and then take some water and pour down it. Let me know how it goes ken
Jan 18, 2009 | Refrigerators
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Trays locked
Hi, I had the same problem and i found out that if you hold down the fast forward and the rewind buttons with the power on and off button it will reset. It took me a couple of goes but after a while it worked. When you do it keep all of the buttons held down and a series of numbers flash for about a minute then it will reset. Good luck, Jeff.
Nov 15, 2006 | Philips CDR796 2-Disc CD Recorder
Stairmaster Stepmill 7000 Pt Logo
65 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
