Question about Columbia All Sport Digi Watch - Men's
Model CA012-007 How do I reset watch to work again after replacing the battery
I have a Coleman digital watch. Four button. I replaced the battery and need to reset the time and date.
Click on your watch model number to open the instruction sheet below.
Your model number is located on the caseback of your watch
go here> http://www.gsi-usa.com/instructions/
Aug 16, 2014 | Coleman Mens Digital Dual Time Sport Watch...
My g shock ga 100 keeps resetting itself back to 12:00 and the analog doesn't stay synced to the digital i have had a new battery fitted and it still doesn't work any suggestions ??
Did you take your Casio to a pro or it was just a normal battery replacement service?.
I am asking because if a pro did it seems he forgot to reset your Casio watch when battery was replaced.
This is a must when you change battery on a Casio digital watch.
Take it again and ask for a complete reset, if they know what they are doing they will do as you ask without questioning.
Casio Watches
Jul 02, 2014 | Watches
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
Replaced battery in lorus digital watch, now the alarm won't work
The alarm spring proabably was lost. If it was, it will not alarm again.
Jul 01, 2009 | Timex Advanced Data Link 53722 Wrist Watch
After replacing battery cannot set mo/day/date
I have the same problem. Watch stores are NO help. Does someone have an answer that works?
Jun 10, 2009 | Seiko SLL086 Watch
My diesel watch gets reset everyday dz-7044110703
I have the exact same problem. The watch was working fine up until I had the battery replaced. I went to another watch repair shop (couldn't go to the same one as I had moved to another town) and the chap there explained that with Diesel watches, when the batteries are replaced a small button inside the mechanism must be pressed to reset the settings, if this isn't done then the annoying problem, inflicting our watches, will occur.
My watch worked fine after, for a few days, then it began to reset again; casting doubt on the watch repair man's explanation. I'll go back to see the chap when I have the time, prob next week and keep you chaps posted on anything new.
Feb 22, 2009 | Diesel DZ7044 Watch
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Error Code Display
Mine did the same thing after changing the battery and would reset intermittently without warning. For some unknown reason I decided to open the watch again. This time I reset the time and date with the back off the watch while deprssing the small spring that is there on the inside . Haven't had a problem since. Don't know if this is the solution but it worked for me. Good luck!
Les H.
Oct 30, 2007 | Timex Sports Ironman Triathlon 100-Lap...
Watches Logo
27 people viewed this question
Top Columbia Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Columbia Watch Expert? Answer questions, earn points and help others
