How to install cutting belt
SOURCE: murray riding lawnmower motion belt routing
I need your model # took look it up , I am a Murray dealer.
The thing to rember there are two kinds of idler pulleys flat idlers that ride on the back side of belts and v pulleys that ride inside the belt . wont be back to the shop until the feb 10.
good luck
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
SOURCE: Need a belt diagram for a husky 42 inch riding
If you have your model number and serial number handy, then enter both here to view available manuals.
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10451
I hope this helps.
DROPNDEAL
SOURCE: Replacing the belt on a Murray Riding Lawnmower.
The simplest way, is to take hold the belt, with the tension from the engine pully/clutch mechanism, then to follow the shape around the rest of the cutter mechanism. (You don't have to worry which direction the belt travels,)
Bearing in mind, the tensioner direction.
Then, you will see the correct route, very quickly:)
Hope you can manage, with that.
SOURCE: Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
