Question about Regal Ware 12- To 55-Cup Stainless Steel Percolator Urn, 13w x 12d
Coffee urn instructions
I lost instructions to my 55 cup regal coffee urn and need help to figure out how much coffee to use for 30 cups
How many scoops do I use in a Farberware 30 cup coffee maker for 30 cups?
About 3/4 cup of coffee will make 10 cups of strong coffee...
adjust to taste...
heatman101
Feb 23, 2011 | Faberware 12-55 Cup Coffee Urn
Where can i find parts for a regalware k1355 55 cup coffee urn
I have a Regalware 55 cup coffee urn, model #K1355. I do not have a part's list for unit. The part I'm looking for is a small switch. It says WR-I think that stands for White Rodgers. It's a four terminal switch two terminals on each side. The numbers on switch are161491 085n, other numbers on switch are250c, 158E,andTf318c. can you help me find this switch.
Jul 31, 2010 | Regal Ware (RW58230R) 30-Cup Coffee Maker
Need instructions for use of Farberware 55 cup Coffee Urn
Hi 2 scoops of coffee to 3 cups not mugs. Then take it from there, adjust to your liking. Ron
Apr 16, 2010 | Faberware 12-55 Cup Coffee Urn
How much coffee do I use for 30 cups
You must use around 7 to 8 gr per cup so you will need 210 light coffee to 240 gr for strong coffee for 30 cups.
Good Luck
Remember to vote for this answer.
Feb 28, 2010 | Faberware 12-55 Cup Coffee Urn
Need pump tube for 55 cup farberware coffee urn.
Hi. Go to repairshack.con. Good luck. bobbyone
Sep 10, 2009 | Faberware 12-55 Cup Coffee Urn
Whay is the coffee to water ratio per cup?
I have the Regal 10 to 30 cup model K7030C.
Instructions read as follows:
CUPS COFFEE
(5-oz serving) ( 8-oz dry measure)
10 ........................2/3 Cup
20.........................1 1/4 Cups
30.........................1 3/4 Cups
Hope this helps
Mar 06, 2009 | Regal Ware (RW58230R) 30-Cup Coffee Maker
10-22 urn
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
Dec 17, 2008 | Faberware 10-22 Cup Coffee Urn
Directions
Thanks for showing me similar problems posted in the past. I was able to figure out that 2 1/2 cups of coffee grounds per 30 cups water was perfect.
Aug 17, 2008 | Faberware 12-55 Cup Coffee Urn
Need measurement guide
We use 'em every sunday at church - 1/2 cup grounds for every 10 cups water. Allowances: finer coffees will use less grounds, and the more you are making, the fewer grounds you need ( or vice versa- the less you are making, you may need to increase grounds a bit, as perk time will be shorter
Nov 07, 2007 | Faberware 12-55 Cup Coffee Urn
Regal Ware 12- To 55-Cup Stainless Steel Percolator Urn, 13w x 12d Logo
20 people viewed this question
Top Regal Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Regal Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
