Question about Medline MDT24SUPRADPS: Mattress Low Air Loss, Alternating Press, Digit
The alarm button keeps alarming
The alarma button keeps alarming
Alarm system keep going off ,only way to turn it off is adjust battery or unhook the battery.
Did you try double tapping the door open button to stop the alarm.
If it keeps going off you need to visit a dealership if it is a factory alarm or an alarm installer if it is an aftermarket alarm.
Jan 05, 2016 | 1998 Buick LeSabre
Eve mon crois watch 9441-FS instruktionbook
Watch controls (eve mon crois) TL= top left button TR= top right button BL= bottom left button BR= bottom right button TL= toggle light TR= view date BR= view alarm time BL= toggle options 1 press --> stopwatch 2 press --> change alarm time 3 press --> change digital time 4 press --> return to regular view (When on option) Stopwatch: TR= stop/start stopwatch BR= reset stopwatch time BL= next option Change alarm time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Change digital time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Normal view: (controls shown at top) In normal view when: TR is held down --> BR= toggle alarm on/off TL is held down --> BL= toggle through days BR is held down --> TR= toggle alarm on/off (for accurate digital time go to the option of change digital time and set it to the next minute from when you are make sure that the the counting seconds are flashing. When the next minute comes press TR this will reset the seconds to '00' without changing the minute and you will now be accurate to the clock you used by less than a second) I got this info through a long time of just experimenting with the buttons, still working on finding a way of changing the date but for now this should be enough to get you by with the watch. Hope this helps somebody :)
Jan 30, 2014 | Watches
Hola buen dia tengo una camioneta silverado 2004 de 8 cilindro se me apago, y se activa el sistema de alarma y en el tablero sale un candado y no enciende
for you, i used the google translator, in 1sec.
the results are here.
Hi good day, I have a truck Silverado 2004 8 cylinder off I go, and activated the alarm system and the board does not get a lock and lights.
I sold my 04 but had no alarm option on mine (i build my own alarms) You need the service guide for your alarm.
if it's a factory opted alarm, then read the FSM on your car.
if not, find the brand and model and google for it.
if this is a keyless entry issue.
see this
http://www.wikihow.com/Program-a-Keyless-Entry-for-a-Chevy-Silverado
Oct 20, 2013 | 2009 Chevrolet Silverado 1500
How do you reset car alarm? put battery in, now alarm goes off and not stop. 2000 mitsubishi montero sport
Hi:
I have montero sport 2000 also. If you call your local mitsubishi dealer and give them your vin number on your rig they will be able to give you codes to punch into probbably your stereo that will reset a factory alarm. good luck...
Aug 07, 2011 | 2000 Mitsubishi Montero Sport
How do I keep the alarm from flashing? I just want to turn off both alarms. Timex nature sounds with cd T621T, Thank you
Hello, To turn off the alarms follow these steps -
  1. After the alarm sounds, press the "F" alarm off/reset button to shut the alarm off but retain the 7-5-2 alarm settings.
  2. If you want to turn the alarms completely off and cancel the 7-5-2 settings, press the "alarm" button so that the "alarm" indicator is no longer visible. As long as you can see the word "alarm" on the display the alarms will continue to go off according to your 7-5-2 alarm settings.
Regards, Tony
Mar 24, 2011 | Timex Nature Sounds LED Clock Radio
Se activo alarama dogde grand caravan 98 3.3l y no tengo control
Hola estoy intentando siguir su problema. esta es hora punta y tenemos muchas preguntas.
Asegurarse que no hay otra alarma que no es de fabrica. En este caso deberia de haber otro modulo de control de alarma. Alarmas no de fabrica suelen tener un boton de deactivaccion (Valet Key) debajo de la console de instrumentos.
Si el pin 34 esta libre, el alarma deberia ser inactivo. Probabilmente se activo' cuando hizo los trabajos en el coche.
Uno de los pins connectados al ~BCM es el alarma.
La unica manera de deactivar este alarma es enviar un impulso al pin del alarma, descargandolo a terra.
Hay que poner una resistencia de 9KOhm en el medio , de otra forma el alarma no se deactiva.
Aqui la esplicaccion:
"Factory Alarm Disarm Wire (-): This vehicle will disarm with (-) negative through a 9000 ohm resistor, must use single pulse to disarm and a double pulse on this wire will also unlock.
Factory Alarm Disarm Wire Location: N/A"
La esplicacion termina con "Factory Alarm Disarm Wire Location: N/A", sin decir qual pin es el alarma.
yo se de otras fuentes que deveria de ser el pin 34. Por esperiencia personal puedo decir que el connector deveria de estar conectado all bloque de aranque.
El hilo deve de ser blanco y rojo o bien violeto y azul.
Si no se pone una resistencia de 9Kohms en el pin apropiado, el alarma no se quita.
No hay otra manera.
Nov 06, 2009 | 1998 Dodge Grand Caravan
Alarm system will not go off in a 1999 vw cabrio
hi, if you have the original stereo, this is the problem, disconnect your stereo, the stereo is connected to the alarma.
To remove the stereo you need two thin plate, put the plates in the slots above the buttons power and mix, and pull the stereo.
Mar 14, 2009 | 1999 Volkswagen Cabrio
Alarm goes off truck won't start.
sounds like you have an aftermarket alarm not factory most of these alarma are equipped with a starter interupt that will not vehicle start. when connecting the battery ist is normal for the alarm to sound some alarms may not sound if ignition is on while connecting battery, however this is not reccomended. after connecting battery and alarm sounds you should be able to turn it off with trasmitter, if you do not have one then you will need to put key in ignition turn it on and look under the dash for a valet switch or togle switch this may override the alarm and let car start if you cannot locate this you can alway locate the alarm box under dash and unplug it as last resort most alarm defaults will let the car start when this is done. hope this helps
Nov 18, 2008 | 2004 Ford F150
Resetting a Bell+Howell Secure Pro Keypad Alarm
We had ours all set up and threw out the manual. When the batteries died then it went back to the manufactures setting. We punched in 4 zeroes and pressed code. Then we put in our new 4 digit code and reset it that way. Hope it helps.
Mar 06, 2008 | Lands Phones
Medline MDT24SUPRADPS: Mattress Low Air Loss, Alternating Press, Digit Logo
79 people viewed this question
Top Medline Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Medline Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
