Question about Golf
Ezgo golfcart/fullycharged will not go into gear/
Batteries are charged/f-r gear shifter is making contact with switch but when touching petal the cart does not move/shift to reverse and there is
no tone to backup/the key is also turned on during this time/ is there a
fuse or something I am missing/or is there a computer part in the run/tow
switch box area to look at.How do you fix this. rwseeger
if email dose not work home phone 1-218-253-4471 thanks
what to do
SOURCE: 1998 Chevy S10 pickup backup lights don't work
Yes it screws in on right side of tramission and you will need a 7/8 inch deep socket to remove it. You may be able to clean the old one once it is removed. There is a little ball thatgets dirty and may you can get by with cleaning it. Good Luck. Ed
Posted on Sep 06, 2008
SOURCE: When I shift to Reverse my reverse lights wont work.
Buy a auto repair manual for your respective truck, or go to the Nissan dealer and ask a tech to show you where the actuator switch is located, and replace that switch. That is the only thing left to replace. That should fix it. Also you could use an Ohm meter to check the switch to see if it is bad. Also check for a broken wire when you remove the actuator switch.
Good Luck!
Posted on Dec 16, 2008
SOURCE: only goes in reverse after recent charging
I would replace the high/low switch and the reverse switch.
I had the same problem of it not going forward, but I just replaced the high/low switch. It turns out 1 month later I had to replace the reverse switch.
Here is the link to the site that I found my switches on.
http://www.shopjandl.com/mepu0003.html
Hope this helps
Posted on Apr 21, 2009
  • 100 Answers
SOURCE: Gear shifter sticking (auto) from Park to reverse and vice versa.
you need to have the shifting cable lubricated or replaced.
Posted on Apr 26, 2009
  • 101 Answers
SOURCE: cranks won't move
Sounds like the clutch is worn out. It sounds like it is slipping so badly it won't transmit enough power to move the bike.
As far as only going in 3 gears with the engine not running, are you spinning the rear wheel while trying to shift it? The trans shafts have to be spinning to be able to shift through the entire gear range.Try shifting it with the engine running and see if you get all 5. If you do, there is no problem with the transmission.
Posted on Oct 05, 2009
EZGO golf cart just stopped. batteries are fully charged. get voltage at keyed on off switch
What is "supposed" to make it go? A pedal on the floor, or a hand operated control? You probably have a bad switch, or dirty or corroded connections, or broken wire somewhere, or maybe a relay with those problems!
May 15, 2017 | Golf
Ezgo cart is fully charged but will go about 3 minutes then slows to a stop
How old are the batteries? Carefully check the fluid level of the batteries. Wear gloves and full face protection if possible as batteries are filled with corrosive acid and there is a chance of explosion. If the cart sat with dead batteries for a extended period of time without being charged the cells in the battery will harden up due to the low charge state making it hard for the battery acid to chemically react with the lead cells when you are trying to charge them. Try replacing the batteries and making sure all of your contacts are clean and are snugly secure.
Feb 11, 2017 | Cars & Trucks
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix -
www.golfcarthotrod.com > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
Aug 02, 2015 | Cars & Trucks
I have a 98 land rovor will not go in to gear ?
it won\'t go into gear as in the shifter does not come out of "park"? or vehicle will not move when placed in "reverse" or "drive"? if its not coming out of "park" you may either have a faulty brake switch or shifter lock solenoid is stuck. on certain european automobiles i have come across the shifter stays locked because the internal solenoid in the shifter assembly has gone bad and the entire shifter ass\'y would need to be replaced. this is the worst case scenario. majority of the time its a bad brake light switch not sending the signal to the shift interlock to release the solenoid within the shifter.
now if your vehicle is failing to move while in "reverse" or "drive" you have some sort of internal failure with the trans. it can be something as simple as a shift solenoid or major such as broken planetary gear.
Aug 30, 2014 | Cars & Trucks
I have an 84 ezgo golfcart the engine will start and run but i can't get enough rpms for the clutch to engage.i have replaced the carb and installed a electric fuel pump.also changed all fuel filters.help...
If you're not getting the proper RPM's try adjusting the timing and check the governor, all golf carts have governor's. If it were me I would
just disconnect it altogether.
Apr 07, 2014 | Peg Perego Vespa Scooter
Battery is fullycharged, but light is very dim
Look for a bad contact either in the switch or the spring that contacts the battery.
Jan 10, 2014 | CREE Zoomable Torch Led Zoom Focus...
Gear shifter is in Park, but dash reads it's in Reverse. Car won't turn over because it is in Reverse now.
You have to locate where the park ignition switch is located. Some are on the transmission and some are in the column under the dash. It probably got moved.
Nov 24, 2013 | 2008 Dodge Caliber
Golf Logo
544 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
