Question about Yamaha RX-V995 Receiver
Power button on yamaha remote is intermitent
The power button only turns on the unit intermitantly
2 Suggested Answers
  • 236 Answers
SOURCE: yamaha dsp-/e300 wont switch on
no display at all in your front panel?
you said power supply is ok... all voltages...
i remember DSPE300, small power amp only IC. can you check your +/- main power supply if ok it should be around +/- 35V. If it's there then place your meter neg to speaker ground, the + to red and try to run on the unit. see if you'lll get a pulse in AC meter mode. Or a DC voltage in DC mode.
then check also your secondary supply that's about +/- 15volts. Your standby voltage for the CPU to work is 5V. please check that as well
If the trouble is main amp, you should still have a display screen. Unless it is a total breakdown and main out totally shorted, it really wont turn on but you said you seem to find voltage.
reden
Posted on Mar 19, 2008
2006 KIA.DOOR LOCKS; When you unlock the doors with remote, the doors immediately lock again. With the key, door unlocks and stays unlocked. however, the feature when you turn key to the right two times...
intermittant is spelled intermittent. .... Ah, locking system. ... You will find a broken wire in one of the doors that are used to set the door lock.
Probably the drivers door return wire.
Oct 26, 2013 | 1998 Honda Civic
1993 Grand marquis radio sound system amplifier trunk mount intermitent reception - radio powered up -volume. tuning. working fine but intermitent soiund received from source to speakers.
you sound like you have a loose wire if your using the stock head unit you must of had to conn.alot of wire go back through follow from the head unit.If I were you get a audio control x-over.it will kick up the pre amp power.
Dec 18, 2010 | JBL Car Audio & Video
Tv turns off intermitently
hi
check your AC cable (change)
2-connctor that ac cable connect into
3- check the button for turning on (not stick)
Jul 25, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
My truck will not turn over! It intermitantly
THIS IS MOST LIKLY DUE TO A FAULTY ELEC. CONNECTION TO THE STARTERS POWER
Nov 29, 2009 | 2008 Dodge Ram Pickup 2500
Need the rca universal remote code for a rca tv we just got from neighbor
0035,0036,0046,0055,0064,0068,0107,0110,0152,0191,0271,0295,1055,1064,1155,1164,1255,1264,1355,1364,1464...
try each 4 digit code. push power, tv, then intermitently press chanel up. the tv has to be on when doing this procedure. when the tv turns off then it is the correct code. then write it down and use scotch tape and put on bottom of remote..goodluck
Nov 09, 2009 | Home
Puchased A Yamaha DSP-A1092 Amp from Auction turns off
I doubt it. Sounds like it is going into protection due to bad output transistors or some such. Time for a trip to the repair shop it sounds like.
Nov 13, 2008 | Audio Players & Recorders
Intermitant powering up
Yes, it is most likely the cradle. My unit did the same thing. Picked up a new cradle and it works.
Apr 07, 2008 | Magellan RoadMate 700 GPS Receiver
Power light on, unit will not turn on with push button
When power was intermittant, were there any other discrepencies or audible power deprivation to the speakers? Your problem has many possibilites from fuses to major amplifier problems to common power supply failures. Being intermittant then dead may still be a simple fix, but not without some physical intervention of test gear. Sorry, Jaszy
May 30, 2007 | Onkyo TX-DS777
Yamaha RX-V995 Receiver Logo
21 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
