Question about Lexmark Z2420 Printer
Will not power on.
I have removed and reinserted the power supply several times. At times when I do this the power light will come on for a second or two and then go out. Other times nothing happens. Any idea why I can't get the printer to turn on?
2 Suggested Answers
  • 3594 Answers
SOURCE: Typewriter will not do anything. Two lights are
Your keyboard is bad, try my tip under WW1000.
DickyO
Posted on Aug 10, 2010
I have a toshiba x205 sli-5 and i think it overheated from sitting on a bed.Now i try to boot up and it beeps 3 times and no display or sound
Greetings,
The BEEP code usually indicates a problem with your memory, cpu, power supply or motherboard.
With your power plugged in, try pressing the power button for 10 seconds.
If your power supply light is blinking unplug the power and remove the battery. Then without plugging in the power cord, reinsert the battery and turn on the computer and see if it boots up. The AC adapter may be defective and need replacing. Your battery may also be defective. You may need to contact Toshiba support at http://pcsupport.toshiba.com
Apr 17, 2011 | Computers & Internet
Hi, My HP NC6400 have a power problem. I have new battery and new power adapter by HP. I tried everything but it does not start. there is blinking light when I connect the power supply to the system but...
Remove the laptop battery for 30+ seconds, reinsert battery and try to charge it then. you can also try testing the Adapter jack (most common issue)
Hope this helps you, have a great day
Jan 18, 2011 | HP Computers & Internet
TV won't stay on! The TV will randomly make a "click/pop" sound and turn off. I will unplug the tv for a bit and then reinsert power cord. The tv will "click" (just like when it is turning on) then a...
Power supply board have problems.It dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 14, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
7340 won't turn on green light comes on for a couple clicks and turn red , it used to turn on but you had to start it several times?
Please check whether the battery is fully charged. Try power resetting the Camera.
Remove the battery from the Camera. Press and hold the Power button for 30 seconds. Then, reinsert the battery after 1 minute and check the operation.
If the issue still persists, service might be required.
Jul 26, 2010 | Vivitar VC-7340 Digital Camera
Will not fax says Error #1203
Good day! Error 1203 means that there is a communication failure between one of the cartridges and the pritner. Try these procedures to help you resolve the problem. 1. Power off
the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on. If no go, 2. Power off the AIO
and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit. Remove
both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on. If the error pops up, there is a hardware problem with the
printer. 3. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to
the middle of the unit. Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. If the error still pops up, continue cleaning or
replace the cartridge. If no error, 4. Do step #3 again for the black cartridge. If error pops up, continue cleaning or replace black cartridge. If no error, print a test page.
Hope this fixes your problem.
Mar 22, 2010 | Lexmark X4270 All-In-One InkJet Printer
Error 2200
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
IF THE ERROR MESSAGE DID NOT COME BACK....
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on the AIO.
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Feb 06, 2010 | Lexmark P6350 All-In-One InkJet Printer
I have just change printer cartridge, the display is now showing printer error 1203 followed by cartridge missing could you assist me with this issue please
Hi!
To resolve the printer error 1203 on your Lexmark X5470 All-In-One (AIO) Inkjet Printer, you need to perform the following tasks---
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on. if the error message return then continue to print a test page. If the test page prints, the error is resolved. If still the power persists then you need to open the top cover of the AIO and remove both cartridges from the AIO. After that power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on and if the error message return then there is a hardware problem with the printer. If error message not return then you need to again power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply and power the AIO on. Open the top cover of the AIO and insert the color cartridge. Close the top cover. If the error message returns then you need to clean the cartridge contacts.
Again try to rest it by powering off the AIO and remove the power supply from the back of the unit. Reinsert the power supply and power the AIO on. Open the top cover of the AIO and insert the black/photo cartridge. Close the top cover. Now print a tests page. If the test page prints, the error is resolved.
Cleaning the Cartridge Contacts
1 Open the top cover of the AIO and remove the cartridges.
2 Remove the cartridges. Clean the cartridge contacts and the AIO carrier contacts.
Checking the Cartridge
To see if the cartridge is defective, replace it with either a new cartridge or a known good cartridge from another printer of this type.
1. Turn the printer/All-In-One off and unplug the power cable from the outlet.
2. Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3. Remove the print cartridges. (For information on cleaning the cartridge contacts, click here.)
4. Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
5. Repeat Step 4 for the other cartridge slot (if applicable).
6. Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
7. Plug the printer/All-In-One back into the power outlet and turn it back on.
You should only follow the steps below to resolve a print quality problem if you have already attempted to solve the problem by printing a "Clean Print Nozzles" page.
Cleaning procedure - Remove the print cartridges. Moisten a clean, lint-free cloth with water. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the downward direction while keeping the print head in downward position on the cloth. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the upward direction of the print head.
With another clean section of the cloth, repeat steps 2 through 4 above. Allow the nozzles and contacts to dry completely. Reinsert the print cartridges. Print the document again. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
If still the error message persists then you need to contact the Lexmark.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Trying to copy something and this error 2200 pops up and states refer to user guide
Hi
This is a scanner lock issue. You may try the following:
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Try a test scan now. If the error reoccurs, then try the below:
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO and using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
If the error still occurs, you may insert the cartridges one at a time and re-check..
hope the above info is of use to you.. try out..!!
Apr 22, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error 2200 lexmark 6250.
hey ,
Follow the steps :-
Step Action
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved...
Nov 15, 2008 | Lexmark X7170 All-In-One InkJet Printer
Replaced colour cartridge and got error 1203
Power off the All-In-One (AIO) and remove the power supply fromthe back of the unit. Wait 30 seconds, then reinsert thepower supply and power the AIO on.
Yes:Continue to Step 2.
No: Print a test page. If the test page prints, the error is resolved.2 Open the top cover of the AIO and remove bothcartridges from the AIO. 3
Power off the AIO and remove the power supply from the back of theunit. Wait 30 seconds, then reinsert the power supply andpower the AIO on.
Yes:There is a hardware problem with the printer. Continue to ContactingLexmark below.
No: Continue to Step 4.4
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the color cartridge. Close thetop cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 4. If you have already tried cleaning the contacts,continue to Checking the Cartridge.
No:Continue to Step 5.5
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 5. If you have already tried cleaning the contacts,skip to Checking the Cartridge.
No:Print a test page. If the test page prints, the error isresolved.
Nov 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark Z2420 Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
