Taiwan Semiconductor Co. TSC TTP-243 Thermal Printer Logo
A
Anonymous Posted on Mar 25, 2014
My printer TSC has a non stop fast blinking red light
Printer is TSC TTP 345
May I know what is the APU used for TSC TTP 244 printer ?
Here is the phone number for their ORLANDO office:
Tel: +1 407 704 8918
E-mail: [email protected]
I examined several documents about this printer but there was NO HINT of APU??
Perhaps the people above can clear this up for you?
Anthony
2answers
My Barcode Printer TSC TTP 244 Plus got problem after printing one line, it got error. I'm using Windows Xp pro SP2 and my setting for printer is Method: Thermal Transfer dan Type: Lables With...
Please check the ribbon installation. The ribbon spindle might have not loaded correctly. You can watch the video clip to verify. http://www.tscprinters.com/cms/upload/download_en/download_232TTP_243_loading_ribbon_E.wmv.wmv
Call TSC Orlando office 407-704-8918 tech support if the problem persists.
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Error ###345
The ink cartridges are
not installed
or a non-supported ink
cartridge is
installedi
or the ink cartridges are
not installed
Check if supported ink
tank(s) is installed, and
re-install them properly,
and then close the
scanning unit.
6helpful
3answers
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
My TSC TTP-245 label printer does not print complete
por fabor necesito las claves de tsc ttp-244 plus pues se me perdieron
Top Taiwan Semiconductor Co. Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Taiwan Semiconductor Co. Office Equipment and Supply Expert? Answer questions, earn points and help others
