Question about Dishwashers
My kenmore built-in dishwasher "clean" indicator light is blinking instead of a steady light. Now nothing will work on the dishwasher. I've tried to cancel, along with other possibilities and nothing seems to work. Any suggestions? Thanks.
  • 530 Answers
Press heated dry and hi temp back and forth till all the lights light up then hit cancel. You have a bad heater if the clean light is blinking
Posted on Jun 15, 2009
Blinking light on Kenmore Pro 13873K dishwasher: won't run
May be the drain pump is jammed. Try to clean the area and after that try to reset the panel. Download the user manual and there must be the reset sequence.
Nov 18, 2017 | Kenmore 13873 Stainless Steel Built-in...
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light will not stop blinking. nothing will work
There are two solutions. The first solution you can try is to turn off the power to the dishwasher and let it reset. If that solution doesn't work it is your control board.
May 13, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 16359 dishwasher
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
May 30, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Kenmore Model 665
The blinking button lights indicate the buttons are bad. The console will have to be replaced.
Mar 21, 2008 | Kenmore 17024 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
163 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
