Question about New Balance Nx301 Heart Rate Monitor
Alarm goes off at midnight
How to turn off alarm
Alarm goes off at midnight every night & I cannot turn it off
Set the alarm for a morning wake up instead of midnight!
Dec 31, 2015 | Watches
The buzzer goes off at 12 midnight every night
You probably have an alarm feature on the radio.
The common default time for timepieces is 12:00.
Find the alarm setting and set the alarm off.
If you cannot turn it off set it for 11 am.
Aug 29, 2011 | GE 7-5290 Clock Radio
Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
Jun 09, 2009 | RCA RP5430 Clock Radio
Turning alarm offI
how do I turn off the hourly setting
Jan 19, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
Motorola ROKR E8 Alarm and Synchronizing Problems
U can flash it, that way at least u'll get rid of the alarm
Dec 26, 2008 | Motorola Mobility ROKR E8 Cellular Phone
Durabrand hm3817dt alarm
I just bought the system yesterday and the same thing happened to me. I didn't realize the alarm was set and it kep going off at midnight. I think I just solved the problem. While the unit is off, press the standby button then the alarm button and wait for the alarm symbol to go away. This should do it.
I have another problem. Every time I turn the unit on, it comes on at about an 18 sound level waking everybody up. This happens even if the radio has been playing on low before turning it off.
Any solution to this problem would be appreciated.
David.
vikdave2006@yahoo.com
Jul 12, 2008 | Audio Players & Recorders
GES050
unplus the radio and take out the batteries for like 10 min...once the machine resets the alarm will stop going off. The same thing happened to mine and this solved it.
May 01, 2008 | Audio Players & Recorders
Alarm goes off at midnight & repeats for half hour, and not set
what you have to do is
1. press the mode button until you get to the setting that has "AL" at the bottom right.
2. then you press the "receive" button to switch between the four alarms.
3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
4. repeat step fout for all of the alarms, and the problem should be fixed.
Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
New Balance Nx301 Heart Rate Monitor Logo
27 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
