Question about Dickie Toys
Mega crane toy repair
Bucket does not raise or lower
953 bobcat loader wont raise bucket
you have this in the toy section so is it a real bobcat loader or a toy
Nov 30, 2015 | Toys
Hydraulics just stopped all of a sudden with bucket up. it will not move at all. what is the trouble shooting steps to follow
OK AL:
SAFETY FIRST!!!!!!!!!!!!!!!
The bucket up is DANGEROUS!
Get some blocking under it before you do anything.
If it were me, I'd find a way (Winch, Crane, Other machine, ???)
to safely support the bucket, then find a way to bleed the lift cylinders to allow the bucket to be lowered to the ground.
Then and ONLY then, I'd be looking at the hydraulics functions to determine if it was a valving or pump problem.
Jul 27, 2015 | Cars & Trucks
My Bobcat 742 Loader will move forward and reverse but the bucket will not raise or tilt.
You more than likely have issues with the hydralic system portion that supports the boom and bucket
Jan 21, 2015 | Toys
Replace cylinder in bottom boom on hiranger bucket truck
ive heard of folks doing it without a crane but i would not try it , alignment is too critical with getting guides and stops back in and with nothing to move boom that would be too difficult
anyways: suspend boom end with double straps from crane , disconnect hydraulic/electric swivels/plugs at truck end lift end of boom slightly with boom all the way extended straight out , remove acess panel (both sides) at jct of upper/lower boom section . remove C clip one side drive out pin oppisite side (wiggle boom to clear pin) locate stops in lower section boom end unbolt , slowly pull upper boom with crane away take care of hydraulic lines and electric wires set on floor on wood cribbing , locate bottom of cylinder truck end find C clip and pin Might be behind a trim cover that might need to be remove drive out pin also remove bottom cylinder hyd hose connect crane to cylinder end move out a foot or so remove top cyliinder hydraulic hose then carefully slide out cylinider with crane , Note if your valves are not tight and new oil will leak back and cause boom base to sag when you unhook hydraulic hoses , your gonna need to block this up with wood cribbing just in case
reverse removal process to install new one , also i would not just install a new seal (you can) with out having cylinder recromed I'll bet it's rusty thats what tears the seals up
and allways replace entire oil volume in hydraulics your old seal is in old oil not good for the new one
Apr 26, 2014 | 1985 Chevrolet Chevy
Remote valves not working.you can raise frontend loader but it want come down. also the bucket want work . change all hyd fittings.and check pump pressure thats good. need help.
Change the filter. If you can lower the loader by loosening a line at the valve, suspect the valve. All lines usually dump to tank at the valve. Make sure that line is ok. If any valves are electric, suspect them even more.
Nov 25, 2013 | Farmall IH Tractor 706, 756, 806, 856,...
I need a clamshell bucket for a Tonka Mighty Crane 758
Only thing I can offer is a link to a current eBay listing for the whole thing.
http://cgi.ebay.com/Vintage-Steell-TONKA-Mighty-758-Large-CRANE-Working-WoW-/300573398306
The only other thing I can offer is a link to Hasbro's Parts Order form:
http://www.hasbro.com/customer-service/orderform.cfm?sku=91046
And you can always call them to see if they can provide the part number even if they don't have tthe part.
http://www.hasbro.com/customer-service/phone-directory.cfm
Good luck :)
Dec 26, 2011 | Hasbro Tonka Toughest Mighty Crane
Farmall 560 hydrolics wont work on the bucket
i am not sure but check the levers and the inside of the lever control movements.
Apr 28, 2010 | Farmall IH Tractor 460, 560, 660, 2606...
Toys Logo
67 people viewed this question
Top Dickie Toys Experts
ray gallant
Are you a Dickie Toy Expert? Answer questions, earn points and help others
