Question about Baby Lock Ellure
Text size is to small
Cannot read the print is to small
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 29 Answers
Press the L button on the screen on the front of your machine when selecting the text.
Posted on Mar 07, 2015
How many pages in a pdf download for Necchi Instruction manual for Necchi Model 3101 FA?
when the down load opens up on the screen, in a small tool bar at the top of the pdf section there are areas that show page numbers , zoom in / out expand size etc the number of pages will be there shown as 1 /24, or 50,or 600 etc ( 1 / of the number of pages in the down load )
if you click on the scroll bar on the right of the page proper and scroll down , as you pass each page break it shows the next page number
if you scroll down the page you will come to a contents list and that will also show the number of sections in the manual and that will indicate how many pages you can expect
to reduce paper wastage from a normal house hold printer when you print from the printer logo in the bottom right of the page you get the printer up and where it says print all , change that to print odd pages ( or even pages ) or or print pages and this is where you put in the pages that you want printed -such as 1,3 5, 7 etc
when the print run is finished put the whole lot of printed pages turned around and back in the printer then print the page numbers that you missed on the first print run this will result in a booklet with printing on both sides of the page and reduce the number of sheets used in printing
Nov 07, 2015 | Necchi Sewing Machines
I need the size of the allenkey
1. Get a Vernier caliper. Preferably both in inches and in millimeters.
2. Use the small inside jaws to measure the inside of the hexagonal screw keyhole, perpendicular to two of the sides.
3. Note the reading both in in and in mm, and convert to the next smallest standard Allen key size. The right key should fit precisely without any wobble.
Dec 17, 2014 | Sewing Machines
How do i enlarge letters & numbers on my Janome 5900 memory craft please
I assume you are referring to the build in letters.
You can't. The L/S key changes the size from its full size to about 2/3 of the full size. That is the extent of their size change. Since these letters are not being formed using the movement of a hoop they can only be big enough to fit in the space allowed by the F foot.
Nov 26, 2014 | Janome Sewing Machines
When I install embroidery hoop light keeps blinking n saying wrong hoop size looked it up n it's saying malfunction
Ok, there are a couple of possibilities, and I'm going to include an image. I"m not sure whether you're trying to use the small or large hoop, but the first thing you should try is turn off the machine, take the hoop off entirely, then turn on the machine without anything and let it reset to its default position, which will be the center. If it has a problem there, make sure the needle it at its highest position.
Next, put the large hoop on, bring up a design, (preferably a design that came with your machine--there are sample designs in the \Library directory where the program is--that's generally in c:\program files\futuraquartet--and is designed for the hoop you're trying to use, and transmit to machine. If it tells you the hoop is the wrong size, download a patch from www.futura-support.com. If it STILL tells you you have the wrong size, reseat your USB cable into the machine and tape it in place with masking or duct tape.
The third possibility--and the one pictured in the photo I'm going to attach--is there is a tab on your hoop which indicates the hoop size, and your TAB may be off. It needs to be dead center of the sensor, which is also pictured. A while ago a BUNCH of hoops were manufactured with the tabs slightly off, and if it's off, your machine can't read the size. What generally happens there, though, is it will indicate that there is NO hoop attached, rather than the wrong size.
You can see the sensors--they're inside the arm where you put your hoop, and they're not covered up. Below it are the large hoop (top), and small hoop (bottom). The hoop tabs have to match up to the sensors exactly, and you'll be able to see if it doesn't by matching up the notch in the hoop that matches the catch in the embroidery arm.
Oct 20, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Thread video needle
Question is not clear? Read the needle? The print is really small and it will just tell you the size. Needles are good for 10 hours and cost and average of 70 cents. If there is any concern about your needle, throw it away and get a different one.
Jan 30, 2014 | Yamata FY920
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
How to thread a old singer # 625 without paying $15 for the owners manuel I want to see if it works first
Hi
You can get free threading guides from www.sewusa.com
I think this is the one you need, it's for the 626 as the 625 wasn't listed.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_626_threading_diagram.htm
I have a Stylist 616 and it is very similar to this machine.
I might be able to send you a copy of the manual for the 616 if is any use to you.
Hope this helps!
Nov 18, 2010 | Singer 7462 Mechanical Sewing Machine
I CANNOT THREAD THE BOBBIN. I BELIEVE THAT I HAVE TAKEN THE CORRECT STEPS. I LOOSENED THE KNOB ON THE RIGHT. THE NEEDLE DOES NOT MOVE. WHEN I PRESS THE FOOT PEDAL, THE MACHINE STARTS RUNNING. THE...
Make sure that you have it wound around the thread guide the correct way, or else you have no tension, and that your bobbin pushed against the bobbin winder. Study your manual, and if you need one with bigger print go to www.singerco.com and download one for free, then adjust your text size. Good luck
Oct 02, 2010 | Singer Sewing Machines
Reading the Embroidery D-cards
I went back to the place where I purchased it and they told me that it was the difference with the size of the hoops. I had to adjust the hoop size before it would accept the settings. That solved the problems. I thought when it was calibrated, that it automatically reset the hoop size - not so.
Nov 04, 2008 | Husqvarna Viking 1
Sewing Machines Logo
18 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
