Question about Dell 1720dn Laser Printer
Dell 1720 dn broken output flag - Dell 1720dn Laser Printer
These are called "top cover right flag" and are available for under $30. Part number D1720-W8 or I believe Lexmark part number 40X5068 also works
Posted on Jul 31, 2012
  • 9 Answers
You can find a junk 1720(dn doesn't matter) and replace the top cover assy. yourself, or you can replace the printer(usually cheaper). Sorry, this is usually terminal for these printers.
Posted on Aug 22, 2009
Brother HL-2040: The Paper LED is flashing, but we did not have a paper jam and have thoroughly cleaned the printer. What to do? It will not print, and we cannot seem to clear the flashing LED ligh
You either have a piece of paper stuck in it somewhere (usually in the fuser on this model) or the flag is broken (usually again on the fuser output). Check the fuser carefully to make sure there is no paper in it and that the flag is intact. It is possible the PCB is bad but more likely there is paper in it or a broken flag. You can drop the back door and see if there is a piece stuck or if the flag is there.
1: open the back door and check for paper.
2: If no paper is present pull down on the output assemble and check for paper there.
3: When you pull down on the fuser output you should see a long thin piece of plastic sticking up in the middle.
If you do not see the flag then it is likely broken. Replacing the printer is cheaper than replacing the output flag unless you have a parts printer hanging around. Good luck and let us know what you find!
Feb 16, 2015 | Brother HL-2040 Laser Printer
Inspiron 1720 no power
Remove main battery and try again, next! sub out the ram memory one at a time and test, have the power supply adapter checked for voltage output, if okay! the DC jack in the laptop is a common source of trouble, "from intermittent operation to no power" at this point the laptop must be dismantled to investigate further.
May 07, 2012 | Dell Inspiron 1720 PC Notebook
My dell 1720 dn has no instruction book and I wondered if I can download one
Hi!
Here's a link for you:
http://support.dell.com/support/edocs/systems/prn1720/en/1720_en/en/index.html
It's not really a download version of the manual, but you can still find all the content via the links on the site.
Hope it helped,
Bogdan
Sep 17, 2011 | Office Equipment & Supplies
Dell 1720 DN- all lights flashing- please advise
try to turn off the printer, remove the power cord, then press the power button for about 5 secs. plug it back, turn it on. If same thing, press the cancel button for about 10 secs. if still the same, try to check the cartridges, remove them and make sure they are not yet empty, shake them a few times, then connect them back. Make sure no paper jam as well.
Aug 30, 2010 | Dell 1720dn Laser Printer
Dell 1720 laser printer shows paper jam after clearing jam and turning off and back on.
some paper piece may be left in the printer.
Please check where was the leading edge of the paper when it was jammed. some sensors may have got stuck while removing paper. open the toner door remove the toner cartridge, just see all the sensor flags with fingers, refix toner and power on and try printing
Dec 01, 2009 | Dell 1720dn Laser Printer
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Flashing:remove output and cannot print
Sounds like the Outputflag is sticking or not returning back to the proper position as quickly as i should. The output flag is gravity return in other words there is no spring required.
Perhaps there is paper or dust collecting in that area and causing the flag to stick... regardless follow these instructions to test this :
The output bin flag on the 1720dn is on the right side. (as you face the printer)
Turn the printer off, hold up the flag while pwring on, wait until al the lights stop cycling. the only light remaining ON (flashing) should be "Remove Output".
Release the Output Bin flag; the light should stop flashing (go out) and the "Ready" light
If this is the case try cleaning that area with compressed air to see if the flag will lower on its own.
Best of Luck
May 18, 2009 | Dell 1720dn Laser Printer
New secondary tray not recognized on vista.
Dell Laser Print 1720 dn Properties window. Click on the last tab called install options. Click the ask printer button. This should update the print driver with the add on drawer.
Oct 30, 2008 | Dell 1720dn Laser Printer
Dell 5200M laser printer
there is a flag in the output bin that lets the printer know when there is too much paper on top of the printer and it stops so that the papers do not continue to feed out and overflow.
Either the flag is stuck in the up position, in which case you can just gently move it so it is hanging straight down, or the flag has been broken off and no longer functional ( in which case the flag and/or sensor would need to be replaced).
May 22, 2008 | Dell M5200n Laser Printer
Paper jam message
A couple of things.
On the left side of the paper path, there is a registration flag type sensor that a small piece of paper can be torn off on.
Also, if the paper has been caught on that flag, it may be broken.
Carefully look with a flashlight for just a corner of a piece o paper left in the machine.
I suspect possibly the flag has been broken on the registration sensor.
Nov 10, 2007 | Xerox Phaser 8500/DN Printer
Dell 1720dn Laser Printer Logo
486 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
