Question about Insignia NS-LCD22-09 LCD HDTV
Tv hooked to cable system and next door neighbor had a lightening strike. After that, the tv does not work any longer--no power light at all.!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Insignia Master
  • 1,001 Answers
  • Multi-color,silver,golden,rose gold decide your choice which you like.
  • High-speed,transmission rate synchronization and transfer music, contacts, quickly and efficiently.
  • Flexible cord,lighting cable perfect forevery house hold ,when you want to use your device in bed or other on soft place
  • Durable,with nylon braided,better to protect the cable.
Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters Lightning Cable USB Charger...
Posted on Jan 04, 2017
  • 10,865 Answers
Your TV got fried when the lightning struck. Time to get another one.
This time be sure you plug it into a surge protector power bar, available at radio shack, walmart, any TV or computer store.
Posted on Jun 15, 2009
What is the likely culprit to troubleshoot on a tv that will not power on and there is no standby light after a lightening strike in the area and fried Directv recievers and tvs?
Hi , it sounds as if the av board is probably fried but it probably did not stop there it may not be worth getting it checked out as that's just another bill to tell you its not worth repairing. Take time to think about it. But get it checked if you wish there is a lot of power in a lightning strike. It could fry one board and pass through the next as they are usually connected.
Mar 10, 2016 | Televison & Video
My ill dads Vizio VO320E showed classic symptoms of lightening damage so we purchased a new main board. Now the screen lights up but is showing pink and yellow horizontal stripes and some vertical sha
Mr. John either one of two things from start u have done right this is a common thing on flat sets hooked to Direct boxes by HDMI having surges come from box to set. The main board usually needs replacing, so either u received a bad board or u have multiple issues and possibly the T-CON board got surged from main board. This board is located above main and power in center at very top of screen. This will cause symptom that u are describing. Hope this helps.
Dec 08, 2014 | Vizio VO320E LCD TV
Why won't my TV turn on after a storm?
Your TV might very easily be destroyed now, from lightening damage. Lightening can come in on the cable, on the power line, all sorts of unexpected ways. I've personally been struck by lightening, plenty hard enough to destroy almost any electronic device... and I was working in a basement at the time.
Jul 30, 2014 | Samsung Televison & Video
Twice now our router has failed to work after lightening strikes. The UPS means its lights still flash etc but the router itself does not work. Why does the UPS not protect it and what do we need to do...
A UPS is generally not designed or manufactured to protect against lightning strikes and / or power surges. Its purpose is ensure that whatever it is supplying power to does not turn off in the event of a power outage. You would be better served by getting a lightening protection strip from a hardware store that comes with insurance against damge from lightening and power surges. Alternately at substantially more cost, you can have an electrician or lightening protection contractor install whole-house lightening protection. Lightening protection strips with insurance included are relatively inexpensive.
Please don't forget to rate this if you found this helpful.
Jan 14, 2011 | Computers & Internet
What causes power door locks,dome lights, trunk release button, and self leveling on 2001 buick lesabre to stop working at the same time
A heavy jolt of electricity like a mini lightening strike will cause all the above to stop working instantaneously..................sodeep
Jul 30, 2009 | 2001 Buick LeSabre
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Altec Lansing ACS45.2-Lightning strike
There is a good chance with a lightening strike that damaged so much of your equipment that this device was also affected. power to the device doesn't necessarily mean that other components were not damaged.... you can elimanate speaker damage by hooking the speakers up to another device to check them.
Robert
Sep 15, 2008 | Dell PART NUMBER KIT SPEAKER MM ACS45...
Suspected lightening damage
yes ligthning damage your unit because of static electricity that increase the power of your power source
Aug 09, 2008 | JVC AV-27530 27" TV
LIGHTENING STRIKE
Ed,
Open the back and take a look at the saw tooth filter cap. It's the largest cap you'll encounter in the PS. Just follow the electrical cord onto the board and look for a VERY large electrolytic cap in that area. Usually they bow at the top on a strike like that. Replacing the cap might restore the unit.
If not do you have an esr meter?
Bill
Apr 28, 2008 | Televison & Video
Insignia NS-LCD22-09 LCD HDTV Logo
301 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
