Question about Logitech Webcam C930e 960-000971
Twain drivers fro c930e
Need twain drivers
Can i use logitech c930e webcam on a android smart tv ?
http://www.bing.com/videos/search?q=logitech+c930e+on+smart+tv&qpvt=logitech+c930e+on+smart+tv&FORM=VDRE
May 13, 2015 | Logitech Computers & Internet
Need Twain driver for windows 7 for canon Scan N12400 flatbeb
The TWAIN drive should be installed when one installs the actual "Drivers" for the unit itself, accordingly I provide you with the download link below.... look for and install ALL drivers and software, especially the Scan manager and TWAIN drivers....
http://usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u
Sep 28, 2011 | Canon CanoScan N1240U Flatbed Scanner
Which software is needed in the computer to use USB from camera to computer
you need to install twain drivers fro it, alternately go to the camera manufacturer's site and download the driver by searching the model no.
Sep 07, 2010 | JVC Cybercam GR-DVP7 Mini DV Digital...
The OEMCFG.dll on Samsung needed
GO TO SAMSUNG/SUPPORT.COM
TYPE IN YOUR MODEL# AND DOWNLOAD THE DRIVERS YOU NEED.
Jul 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I need a twain driver
I can understand that u get TWAIN driver not installed or required error on PC while scanning.
Twain drivers are imaging driver which are bundled with complete software.
Incase if you try to replace just the twain driver it may corrupt anoth files.
It is always advisable to clean the computer and reinstall the complete software.
Jul 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Cannot communicate with twain devise
I suggest using ISIS drivers instead of TWAIN. I have always had trouble with the twain drivers failing especially in paperport ive found the ISIS drivers to be much more stable.
If you do require TWAIN though best way to fix is un-install the software that the TWAIN driver came with and re-install it. Unfortunately thats the easiest solution.
If you want to try the isis drivers they should be on the cd that you used for the twain drivers just select isis instead.
Let me know if you need further assistance.
Mar 22, 2009 | Brother MFC620CN Home/Office Color Inkjet...
Genius and Vista
In a communication with the genius scanner manufacturer, their response is pasted below.
I regret to inform you that the vivid 4 is not compatible with Vista.
Airo
KYE SYSTEMS AMERICA
e-mail support: support@genius-kye.com
MSN Messenger Support: support@genius-kye.com
Phone # 305-468-9250 ext: 30
xp.gif< ----------------------------------------They also state that the product specifically states what it is compatible with and does NOT state it is compatible with Vista. :(
Oct 10, 2008 | Office Equipment & Supplies
Genius and Vista
There are two common ways to software-connect scanners
to windows:
1) The TWAIN driver interface
2) The WIA (Windows image acquisition) driver interface
WIA is a driver interface native to Windows:
http://en.wikipedia.org/wiki/Windows_Image_Acquisition
TWAIN is a driver interface specific to each scanner
Most new scanners should support both driver interfaces !
TWAIN is preferable, if you can find it, because it is tightly
coupled to the scanner's hardware design, and therefore offers
more functionality, which is hardware specific.
WIA, on the other hand, is more generic.
It will work with many different scanners, but with reduced
functionality, especially in the tools and setting available within
the scanner control window that pops up every time you try to
scan a document from within an application.
If you cannot find TWAIN, you may have to settle for WIA.
(if it will run with your hardware)
This biggest problem, of course, is VISTA itself, and it comes
in two flavors, depending on your computer CPU:
64-bit and 32 bit.
64-Bit Vista drivers are the hardest to find.
32-Bit Vista is a DOG, because the software is too bloated
to run on a 32 bit machine.
Fancy colors and GUI not withstanding, 100% of the added
"new functionality" within Vista is for the benefit of Microsoft
and the scumbags running Hollywood. Vista hi-jacks your
expensive hardware resources and slows down "YOUR"
machine at "YOUR" expense to promote Microsoft's
insestuous relationship with the Sony movie studios and
the RIAA.
I strongly recommend to all my clients to stick with XP for
now, and avoid Vista like the plague.
I do !
Martin
Jul 12, 2008 | Genius ColorPage Vivid Pro II Film Flatbed...
Twain driver for scansnap s300
The scanner can not be used with Twain.
3 TWAIN or ISIS® applications cannot be used directly.http://www.fujitsu.com/us/services/computing/peripherals/scanners/scansnap/s300.html
Apr 12, 2008 | Office Equipment & Supplies
Logitech Webcam C930e 960-000971 Logo
129 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
