Question about Epson EX50 LCD Projector
Flashing black vertical lines
Display has flasing black vertical lines every other row of the display. What does this mean?
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
Rows of vertical lines on my laptop screen
check the computer for infections.
if no infections found, then check for display driver and it services..
Mar 09, 2012 | ASUS K60IRBBBR05 Notebook
Vertical lines on lcd display, just a few at first but getting worse
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Dec 29, 2010 | Toshiba Satellite P105-S6104 Notebook
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
Error flashing display, what to do?
You may find solution if you find the link to Nike watch manuals in my tips.
Feb 02, 2010 | Nike Lance 4 Wrist Watch
Vertical lines on startup. code 43 Adapter display. 8800GTS win 7
check to see your direct x status by typung dxdiag in run and test if they all pass then I would check the card wattage rating and you max power supply load the card may be to much for your power supply
Feb 02, 2010 | Leadtek GeForceĀ® 8800 GTS, (320 MB) PCI...
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Jul 19, 2009 | ASUS Eee PC 1000H Laptop
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
Epson EX50 LCD Projector Logo
15 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
