Question about Laser Tek Services Oki C9600 4Pk Okidata C9600 High Yield Toner Refill Kit 4 Pack For Okidata C9600 9600 C9600N C9600Hdn C9800 C9800Hn C9800Hdn 9800 Okidata 42918904 42918916 42918903 42918915 42918902 42918914 42918901 42918913 Printers And Cartridges. 4 Reset Chips I
Oki c9600 shows MP Tray overfilled and there is no paper in the tray PLEASE HELP!
I replaced the MP Tray of the Oki c9600 printer and now the printer shows MP Tray overfilled and there is no paper in the MP tray
OKI C9600 paper jam problems: Paper jams continually, either on first attempt to printing or if it prints a page the 2nd page inevitably jams. Printer has only done 1500 pages since new ,and i have removed...
Wow! That's quite the printer you have there. The C9600 does have a feed roller in the front; and it's not uncommon for paper to still get stuck. Does your paper "fan" when it goes through; or simply, go through and jam? It's possible a paper feed sensor is bad too. Another thing you might want to check is the paper tray; and that the paper is set to the proper size.
Also be aware, the OKI 9600 had a recall a year or so ago for some potential "shock issues" I would advise you to check with OKI directly to determine if this printer is part of that issue too.
Jan 04, 2011 | Office Equipment & Supplies
OKI 5200C printer keeps miss feeding on MP tray
Clean the rubber-wheel! Click and pull it off.
Mar 02, 2010 | OKI C5200n Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
Oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Apr 14, 2009 | OKI C5250n Printer
Printing envelopes on the Oki C5250
There are 2 entrances into the multi purpose tray. The one I needed access to opened from the sides and not the front (which opened the entire front cover). There was then a flap inside which allowed me to adjust the size of the documents to feed in, including envelopes, which the main tray doesn't.
Mar 18, 2009 | OKI C5250n Printer
C9600
chweckcthere is not any paper jam . remove inkcartrdge then check .aslo check in back side of printer .may be there is paper jam.
remove paper if jammedup.let me know.
Jan 24, 2009 | OKI C9600hdn Laser Printer
" Load MP Tray Letter"
Pull down the MP tray and load paper into it.
Jan 05, 2009 | Office Equipment & Supplies
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
OKI B4100 paper output. Frustrating!
If your oki is like the 4300 we use it may be as simple as making sure the extention for the back tray (where the paper is printing to now) is pushed all the way in. This actually selects the tray option. If this tray extention is pulled out at all, your printer will print to the back tray.
Oct 25, 2007 | OKI B4100 Laser Printer
Laser Tek Services Oki C9600 4Pk Okidata C9600 High Yield Toner Refill Kit 4 Pack For Okidata C9600 9600 C9600N C9600Hdn C9800 C9800Hn C9800Hdn 9800 Okidata 42918904 42918916 42918903 42918915 42918902 42918914 42918901 42918913 Printers And Cartridges. 4 Reset Chips I Logo
44 people viewed this question
Top Laser Tek Services Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Laser Tek Services Office Equipment and Supply Expert? Answer questions, earn points and help others
