Question about HP Photosmart C4240 All-In-One InkJet Printer
Says no ink detected
Won't let me print anything because the ink isn't detected.
Cannon mp495
The printer will detect if there is any cartridges that has run out of ink and will not print until the empty ink cartridges have been replaced.
Jun 27, 2012 | Canon PIXMA MP495 InkJet Printer
Printer won't let me photo copy anything
have you checked ink supply. wont copy if there isn't ink
Aug 25, 2011 | Office Equipment & Supplies
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
Just changed ink cartridges and unable to use printer. Keeps stating printhead missing or has come loose but it isn't. Before this happened, wouldn't print the black ink after I'd installed...
Hello
Your printhead is bad and you should have it replaced.This should cost you about $56 if you are in the US
Also you should reolace all the waste ink absorbers,reset the counter to zero and re-insert the ink cartridges.
To replace the ink cartridges
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Jun 12, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
Won,t print
Take it back and buy an Epson brand.
Feb 05, 2009 | Epson Stylus CX3200 All-In-One InkJet...
HP Photosmart C4240 All-In-One InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
