Question about Saws
Parts Cant find anyone with trunnion assembly in stock
    Sergeant:
  • 468 Answers
What is the brand and mode of your band saw? Check bandsawparts.com
Posted on Sep 09, 2014
Trunnions for delta 28-276
Check toolspartdirect . com . They have a trunion assembly for your bandsaw.
May 31, 2014 | Delta 426023950005 Trunion Assembly
Need to replace trunnions under bandsaw table (14inch craftmaster)
I have a band saw parts supplier and they have good deals. But they don't trunnions. I suggest you try to check with amazon.
Mar 18, 2013 | Saws
The trunnion is broken
Try checking with ebay or amazon. I purchase aftermarket band saw parts and I have a supplier . Unfortunately, they don't have trunnion.
Mar 11, 2013 | Craftsman Saws
Need trunnion for Model 28-540 Delta 16" band saw part 419-96-095-001
I used to purchase replacement parts on bandsawparts.com . Have you tried checking on mike tools or ereplacement?
Mar 02, 2013 | Saws
I NEED A RELPACEMENT REGULATOR AND HOSE ASSEMBLY FOR A Q3000: iS NOT APPARENTLY STOCKED BY ANYONE AND THE UNITS STOCKED ARE TOO SHORT.
According to the Weber web site http://store.weber.com/parts/gas/g2_ttbl_rht.aspx their parts page list the Hose/Regulator Assembly for your grill as 14.5 " long. Part # QCC1, for a price of $24.99.
I bought one at Home Depot two weeks ago that is 20" long for the same price.
So, apparently the hose/regulator assembly is stocked by Weber.
Apr 19, 2011 | Weber Q Grill
The blade isnot square with table
You can adjust the trunnion assembly from the bottom side of the table. Most saws have 6 bolts that bolt to bottom of top. if you loosen all six bolts then shift as nessessary to align to top top, then retighten the bolts. The holes in the trunnion assembly brackets should be oblong to allow this ajustment, Jim
Jan 23, 2010 | Craftsman 10" Table Saw
How do you get the rear u-joint out of the drive shaft on 2005 chevy avalanche
It will need to be pressed out.
Universal Joint: Service and Repair
Nylon Injected Ring
Universal Joint Replacement - Nylon Injected Ring
^ Tools Required
- J 9522-3 U Joint Bearing Separator
- J 9522-5 U Joint Bearing Spacer Remover
Disassembly Procedure
Notice: Never clamp propeller shaft tubing in a vise. Clamping could dent or deform the tube causing an imbalance or unsafe condition. Always
clamp on one of the yokes and support the shaft horizontally. Avoid damaging the slip yoke sealing surface. Nicks may damage the bushing or cut
the lip seal.
1. Support the propeller shaft in a line horizontal with the table of a press.
2. Mark the propeller shaft as to which end is the transmission end and which end goes to the rear axle.
3. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1 1/8 inch) socket.
4. In order to shear the plastic retaining ring on the bearing cup, place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out
of the yoke ear.
5. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue to press the bearing cup out of the yoke.
6. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
7. Mark the orientation of the slip yoke to the tube for proper reassembly.
8. Remove the cross from the yoke.
9. Remove the remaining universal joint parts from the yoke. If you are replacing the front universal joint, remove the bearing cups in the slip yoke
in the same manner.
10. Inspect the retaining ring grooves for plastic.
11. Inspect the bearing cup bores in the yoke ears for burrs or imperfections.
12. Clean the remains of the sheared plastic bearing retainers from the grooves in the yoke.
13. The sheared plastic may prevent the bearing cups from pressing into place and thus prevent the bearing retainers from properly seating.
Assembly Procedure
1. Remove the bearing cups from the universal joint.
2. Assemble 1 bearing cup part way into 1 side of the yoke.
3. Turn the yoke ear toward the bottom.
4. Assemble the cross into the yoke so the trunnion seats freely into the bearing cup.
5. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
6. Assemble the opposite bearing cup part way into the yoke ear.
7. Ensure that the trunnions start straight and true into both bearing cups.
8. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for a free unbinding movement of the
trunnions in the bearing cups.
Important: If there seems to be a hang-up or binding, stop pressing, and inspect the needle bearings for misalignment in the bearing cup.
9. Press the bearing cup into the yoke until the bearing retainer groove clears the inside of the yoke.
10. Assemble the bearing retainer in the retainer groove.
11. Continue pressing until you can snap both retainers into place.
12. If seating the retainer is difficult, spring the yoke slightly with a firm blow from a dead blow hammer.
13. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so the snap ring seats in the bearing cup groove.
External Snap Ring
Universal Joint Replacement - External Snap Ring
^ Tools Required
- J. 9522-3 U-Joint Bearing Separator
- J 9522-5 U-Joint Bearing Spacer Remover
the lip seal.
2. Mark the propeller shaft in order to show which end connects to the transmission and which end goes to the rear axle.
3. Disassemble the snap rings by pinching the ends together with a pair of pliers.
4. If the ring does not readily snap out of the groove in the yoke, tap the end of the cup lightly in order to relieve the pressure from the ring.
5. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1-1/8 inch) hex head socket or a 27 mm (1-1/16 inch) socket.
6. Place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out of the yoke ear.
7. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue pressing the bearing cup out of the yoke.
8. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
9. Mark the orientation of the slip yoke to the tube for proper reassembly.
10. Remove the cross from the yoke.
11. Remove the remaining universal joint parts from the yoke.
12. If you are replacing the front universal joint, remove the bearing cups in the slip yoke in the same manner.
13. Inspect the retaining ring grooves for dirt, corrosion, or pieces of the old ring.
14. Inspect the bearing cup bores for burrs or imperfections.
15. Clean the retaining ring grooves. Corrosion, dirt, rust, or pieces of the old retaining ring may prevent the bearing cups from pressing into place o
Assembly Procedure
2. Assemble 1 bearing cup part way into 1 side of the yoke. Turn the yoke ear toward the bottom.
3. Assemble the cross into the yoke so that the trunnion seats freely into the bearing cup.
4. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
5. Install the opposite bearing cup part way into the yoke ear.
6. Ensure that the trunnions start straight and true into both bearing cups.
7. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for free unbinding movement of the
Important: If there seems to be a hang up or binding, stop pressing. Inspect the needle bearings for misalignment in the bearing cup.
8. Press the bearing cup into the yoke until the bearing cup retainer groove is visible over the top of the bearing cup.
9. Assemble the bearing retainer in the retainer groove.
10. Continue pressing until both retainers can be snapped into place.
11. If the retainer is difficult to seat, the yoke can be sprung slightly with a firm blow from a dead blow hammer.
12. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so that the snap ring seats in the bearing cup groove.
Oct 30, 2009 | 2005 Chevrolet Avalanche
I need to buy the water tank, but cant it online.
Model has been discontinued. But they have some parts in stock. My iron assemble won't turn on anymore, but everything else works. They can't help me, but maybe they can help you. 1800-233-9054
Oct 25, 2007 | Westinghouse WWSR1 Iron
Saws Logo
51 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
