Question about HP 12A Toner (Q2612A) Printer
Double sheding printing
Black shando & double printing
Screen is very dark, bearly see the maps, was good last time out. boat is always sheded.
check all wiring and connections for corrosion damage that is putting too much resistance in the line and is not allowing full voltage to the unit
Jan 06, 2016 | Boating
I changed two colour ink cartridges on my Canon iP4200 printer. Now it won't print colour. The pattern check does not print any colour.
You might want to double check to make sure that your printer takes two color cartridges? If I remember correctly, the Pixma takes one black and one color cartridge? If you put a color cartridge in the black ink assembly that would cause it to stop printing.
Double check and make sure that you have one black cartridge in the correct place and one color on the other side.
Apr 22, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
HOW do I print on both sides of paper automaticly
First, you need to have the HP Automatic Two-sided Printing Accessory (Duplexer) installed on your printer for it to print double side. If you have it installed, depending on your operating system follow the information on this page: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=au&lc=en&dlc=en&product=3760410&tmp_track_link=ot_search#N242
Feb 05, 2011 | HP Officejet Pro 8000 Wireless InkJet...
Why does my hp 1220c print letters double struck type red/black i
check you cartridge, is it new and genuine, if you have not troubles in cartridge, check the cleannig station
Mar 30, 2010 | HP DeskJet 1220c InkJet Printer
Double printing of words and black marks
you need to strip your fuser unit out and clean you heat roll
Nov 30, 2009 | Canon ImageClass MF5770 Laser Copier...
Quality of black prints with double image
Discovered it was a faulty ink cartridge. Had to return it to Staples.
Nov 20, 2009 | Dell 924 All-in-One InkJet Printer
Can't print and when i did got green color
Check the level of your black ink. Double click on your printer icon. This should bring up Dell solution center. Click maintenance and it show the level of your black and color ink. If it appears you have black ink you might try clicking on your menu file, print click on preferences, check print black and white only. If you don't get a printed page. You're for sure out of black ink.
If you get a black printed copy, Double click on your printer icon, click on the maintenance tool to clean and test nozzles.
Jul 01, 2009 | Dell A920 InkJet Printer
HP laserjet 5000 series PCL 6 driver
have you tried from the print command dialog box from pc
Apr 28, 2008 | HP LaserJet 5000dn Printer
Can the 420CN print double sided pages
There is only a manual double sided printing avaiable:
After the first side was printed you have to turn the page into the papertray again.
Canon bubble jet printers can do double side printing but the back side black print will be mingled through C/Y/M ink!
Jan 07, 2008 | Brother MFC 420CN All-In-One InkJet...
HP 12A Toner (Q2612A) Printer Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
