Question about Audio Technica Audio Players & Recorders
Static/crackling when playing records
Connections worked well before system was moved to new location. Does the amp have to be grounded, and if so, how?
  • 85 Answers
SOURCE: static but no music from the satelite trebble speaker
Try to reconnect all the wires, the problem seems to be with connection. Instead of spending lot of money on speakers, you can buy just the wires, they are pretty cheap. Hope this helps.
Posted on Jul 27, 2009
  • 140 Answers
SOURCE: Static/crackling noise through speakers when try
You may have broken the connections of the amp module. You have to look at the circuit board verry closely
Posted on Jan 15, 2010
  • 5603 Answers
SOURCE: recording quality just went downhill fast.
Make sure your computer audio is NOT set to "echo" as this will loop the audio back out. This setting can sometimes get set by whatever... it happens.
Posted on May 01, 2010
RaidX
  • 632 Answers
SOURCE: hit bump and subs and amp wont work
Loose wire or connection is causing stereo to short out, Check all connections including amp,Stereo,Speakers and make sure nothing is touching places it shouldn't
Posted on Jul 31, 2010
  • 2973 Answers
SOURCE: The radio/cd player in my
The static type sound could be due to fine dust in the volume and other such controls. Please use a vacuum to blowout the dust from these controls. The connections may be OK.
Posted on Sep 13, 2010
Sony stacking system LBTd505, the sound from the record deck suddenly went very faint. The cd and radio sections are fine. I have tried a new stylus, but no difference. Any ideas?
You have two options. First a faulty cartridge. Or a faulty pre-amp in the main amp.
You can find out if the cartridge (and amp) are playing up. By removing the connectors on the cartridge.
Then with the volume turned up to about half, with your finger, touch each one of the wires one at a time. It will not harm you at all. But you should hear a loud buzz on one wire on the right and a loud buzz on the left on another wire.
The two other wires will either produce a crackle, or a tiny buzz, or nothing at all.
If you do hear a loud buzz on two wires. The cartridge is faulty and needs replacing.
If you hear a slight buzz on them or weak sound. There is either a bad connection between the deck and amp. Or the pre-amp inside the deck which is only used by the record deck so will not effect any other function, is faulty.
You can remove the record deck connections to the amp and again with the amp on half full, touch the inputs with your finger. If you are not hearing a loud hum or buzz, the pre-amp is faulty. If you do the connectors are faulty.
Jun 11, 2016 | Sony Audio Players & Recorders
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
I have a crosley record player, the kind that can play CDs, iPods, tapes, and is a radio too. When I play records either no sound comes out of one side or just static. Both sides get static though. It's...
It's possible that the wires that connect the cartridge where the stylus fits are loose or broken off. With it set to the deck, have the amp on. Lift up the arm and touch the wire connections to the cartridge. You should hear a buzz on each of the channels depending on which wires you touch. You can also disconnect the wires from the cartridge and carry out the same test. On one wire it will buzz on the right, on the other on the left. The two other wires are earths and will cause only a slight buzz or nothing at all. This test proves the pre-amp inside the amp is working. If the wires are connected properly to the right connections on the cartridge, you should hear sound. If the connections are good and the sound poor or absent you need a new cartridge.
Aug 24, 2014 | Audio Players & Recorders
I have a NAD turntable. I have noticed that on occasions there seems to be a background crackle.. Thought it was dust at first !! Have swapped the connection over where the turntable plugs into the amp....
Either you have a poor earth connection or you are getting a lot of static from the records you play. The best way of getting rid of static is a spray you can get for cleaning records. Search on-line for Anti-Static Record Cleaner.
Jun 15, 2011 | NAD 533 Turntable
Hit bump and subs and amp wont work
Jul 29, 2010 | Jl Audio Class D E1400D Car Audio...
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
5 computer speakers w/ subwoofer
1) Check the connections of your speaker wire at both the speaker and the PC. It's possible something might have come loose or is starting to become worn.
2) Try moving the speaker or your tower/cpu to another location, or if not, move any new accessories away from the speakers and wires. It is possible that you are getting interference from a new accessory or appliance (like printers or other electromagnetic devices).
3) Let me (us) know what the brand and model of speaker it is. Maybe there's more specific info we can provide.
Dec 27, 2007 | Panasonic RP-SP28 Computer Speakers
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
