Question about HP Compaq 6720s Notebook
Attempting to remove the switch cover but the side of the cover (silver) dont move Any Ideas
  • 788 Answers
This is the second time I have responded to this question and hope that this time it is recorded.
1st. I don't know which switch cover you are in question of.
2nd. The only switch cover is the panel where you'll find the Led's or the Touch Panel.
3rd. If this is the panel in which you are asking, let go on. ( If not let's not)
4th. Disconnect all power to unit.
5th. Remove the battery and any media you may have in the unit.
6th. Lay unit on its back (lable up, where it can be seen)
Their are 2- Covers which can be removed. Not knowing why yo want to remove the cover, does not help. So, I will explain how to remove the Touch Led Cover.
7th. With unit on its back and Lable facing you. Please find the first row of rex screws on top of battery Bank. You will see six but only 4 of the six need to be removed.
From left to right 1st screw Yes, second screw NO, third Yes, fourth Yes, fifth NO, six Yes.
The two screws remaining are for the LCD hanging and you don't need to remove them.
8th. Know that you have removed the top set, you can remove the next set,
which are silver and cant be missed.Remove these 3-Silver screws and flip unit over.
Open the cover and before you attempt to remove this cover, you should know of 3- items underneath which are very fragile.
Their are 2-Ribbon cables (12pin) and 1 Mic cable
With your hands on both sides you should be able to lift cover upwards, allowing it to fall over towards you.
9th. You will see 1 4-pin black plug and 2 12 pin ribbon cable connectors.
My advise is to treat this area like it was eggs on grass.
To completely remove these 3 connections
1. disconnect black 4-pin connector
2. Their is a thin plastic brown clip on the top of the connector, which lifts up only about 5 mm
which isn't much!
Remove the two ribbon cables and you are their.
Re-assumable the reverse.
Hope this finds you in good health, in mind and computer.
John Ray
johnrraycomputer.com
john@johnrraycomputer.com
Posted on Jun 16, 2009
How do I remove the printer cover? One of the hinges has broken!
Pop the toner door and remove those 2 silver screws. Remove the toner and cassette tray. Gradually from the rear, pull and lift the cover from its corners and slowly lift this upper cover off printer. The 4L is pretty easy, unlike the 4P that you must remove the connection plug on its side cover.
Jan 14, 2015 | HP LaserJet 4L Printer
Beko instructions
You will have to remove the hinge cover at the top. Usually just snaps down on top of hing or could have a few screws.Then remove the screws securing the hinge. Make sure you make a diagram or take a few images of how its put together (they can be a pain if you forget how). Before you do that look at the top center, and lower sides of the side you want to put the doors on, not all units are made to be reversible. If yours is there should be plastic snap in covers covering the screw holes. Remove the covers, move the door and gaskets, etc over, align properly and put plastic covers in holes on side you removed doors from.
Aug 20, 2014 | Beko CF7914APS Silver 348 l Fridge Freezer...
Airforce WAP-35DIH A/C unit not working
I had the same problem, i just fixed mine. it's easy. unplug it first and give it a moment to discharge the capacitors so you dont get a shock..
1. remove the back cover by unscrewing and pulling it up and out. it may take some wiggling.
2. unscrew and remove the front cover - screws are at the top inside the back of the unit
3. face the front of the unit. in the bottom left corner is a silver tube held in place by 2 screws. remove the bottom screw and slide the silver tube out to the left so its dangling on its wires.
4. beneath the silver unit is a panel held by 1 screw. unscrew it. the panel is long and flat...coax it out of the front of the machine from underneath everything it sits on. dont disconnect the wires tho. the panel is long, you can push from the back of the machine as well as pull from the front. wriggle it out.
5. a piece of rectangular polystyrene will come with it . this is the float. on top of the long panel is a (reddish) switch. as the water rises, the polystyrene floats up and pushes on the switch.
6. clean off the polystyrene and the water tray beneath it, check that the flap flaps freely.
7. carefully (live wires around!) plug in the air con and check that with the flap dropped down (not pushed up) the aircon unit works.
8 if so, hooray, reassemble everything. job done.
Jul 11, 2013 | Cell Phones
Wont go into drive
A problem exists in the neutral safety switch, or the brake switch that tells the sensor the brake is on and allows it to shift into drive or other gear..there is a bypass for this ,if the shifter is on the floor, it ison the right side of shifter,you will need to remove the console cover, it looks like a silver button with a spring under it..If shifter is on steering column,,the cover will have to be removed,and the same buttonwill be visible...Replace the Brake neutral shift switch either way....about$37.50 and 3 hours work..Good luck
Sep 13, 2012 | 1998 GMC Suburban
How to install new lcd screen
Installing a new LCD is fairly easy in this model.
#1 Remove two bottom screws
#2 Remove four side screws
#3 Slide off silver side panel on the left Front side of the camera
#4 Carefully remove front cover (careful to pry off from the top)
#5 Flip over front cover and release the power panels ribbon cable from the system board
#6 Flip over plastic protector
#7 Remove Back Cover from LCD side
#8 The LCD is being held by 3 ribbon cables.
(This next step should be done very carefully - damage can occur if it is done incorrectly)
#9 Release the middle ribbon cable by carefully flipping up the black portion of the clamp.
Equal pressure should be applied to the full black portion when attempting to flip open.
Do not use excessive force.
#10 Release remaining cables and remove LCD.
To assemble just reverse the steps. We have color diagrams available just ask.
Thank you
Jan 24, 2011 | Sony DSC-T70 Digital Camera
Brewer leaking
Lyne,
If your Brewer is registered with Keurig you can call Customer Service and explain your problem. Most likely they will send you a new one. I'm on my third replacement. Taking the Brewer apart is difficult to say the least. I still have the last B70 Brewer that they replaced. Have been trying to get it apart without much success. If you search "Keurig removing panels" there is an answer to have to rmove the panels but it isn't complete enough to help.
Apr 30, 2010 | Keurig B70 Coffee Maker
How to intall battery in motorola v220
Dear i have send three suggestion for the change the battery.
1. This is something a lot of people had struggle with. You use your index finger's nail, press the upper cover part (located on the top part of the phone) this way you move away of the phone. Ladies be careful with the nails, especially when removing the actual battery, it can be tricky. But again follow the same procedure for the cover and the battery as well. Consult your owner's manual, if not go to your nearest authorized store and get assistance: remember that there are sensible parts on this area that can get permanently damaged. :o)
2. on the back.. on top.. near the hindge.. there should be a silver slot.. push it down with your thumb nail and pry it off.. dont worry. it wont break.. then when you see the battery.. put both thumbs on either side of the top battery where the slot is.. then push the battery down and pull up.. and itll come out.
3. remove the back cover by pressing the silver button down hard then press the top of the battery down then pull it back and then insert the new battery.
Mar 23, 2010 | Motorola Mobility V220
I cannot open my compaq evo d51s, any ideas?
I just removed one of these cases.
The silver face-plate is attached to the cover that you wish to remove. The black plastic just below the silver is a part of the base.
  • With the face of the computer towards you, place your thumbs on the black plastic below the face-plate.
  • Use your fingers to press into the side-buttons.
  • Using your thumbs to push against the base, pull the cover towards you.
Nov 20, 2008 | Compaq Evo D500 PC Desktop
About removing sim from htc mobile
You have to remove the back cover, and on the left hand side there is a removeble cover (the silver strip on the side of the phone). When you remove that, you will see on the left the sim card. Press it in with you finger nai and voila.
Mar 06, 2008 | HTC Touch P3450 Smartphone
HP Compaq 6720s Notebook Logo
185 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
