Question about Rowenta Steam Generator DG050 Iron
Switch doesn't work. can it be repaired
It just doesn't work.
Russell hobbs iron
If parts are available yes
Nov 14, 2013 | Irons
It is my first time using it, I brought it from USA and it is not working at all!!
follow this steps and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electric cord and check the thermostat .
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jun 11, 2013 | Black & Decker Irons
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
How to remove cord on Rowenta DZ2061
Your iron probably has tamper proof outer screws with a center pin...don't be intimidated. First, try to remove the screws with a tiny screwdriver from an eyeglass repair kit. If that doesn't work, get a Torx T-20 nutdriver attachment.
If you have to replace the cord, here's a possible supplier: Smallappliance.com
Oct 05, 2012 | Rowenta DZ2010 Iron
My iron doesn;t work after it fell ..my iron is a steam and nonsteam what will i do to fix this?
Something would of broken inside the iron, and you will find it dearer to Repair than to buy a new one. If your smart pull it apart and try to mend it yourself. sorry I cannot help you fix it.
May 19, 2010 | Tefal UltraGlide 1759 Iron
Euro-pro ep8001 steam iron
I found the fix myself.
I found a switch without the light and it works
Sep 08, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator EP8015 - Rocker switch
The screws holding the unit together are T-20 TORX screws; the center post makes them anti-tamper TORX screws. These screws are used in applications in which the manufacturer does not want the average consumer to attempt repairs. Please don't take this wrong, but if you have to ask about the "unusual 6-sided screw", then you shouldn't be opening the unit.
Unfortunately, when the heating element rocker switch gives out (3-4 years), it is usually about time to overhaul the entire iron (both the tank portion as well as the iron portion). Other things that can cause problems are the thermostat and the pressure actuator.
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
Feb 25, 2008 | Euro-Pro Steam Generator EP8001 Iron
No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Jan 03, 2008 | Euro-Pro Steam Generator EP8001 Iron
Rowenta Steam Generator DG050 Iron Logo
67 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
