Esselte ch3000 Plastic spring to handle connector broken on the esselte ch3000
5 Suggested Answers
  • 3 Answers
SOURCE: Broken handle - again
See Sears parts online. They have better pricing than a couple of other online appliance parts places I have seen. The URL is provided below.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDB5600AWB&productCategoryId=0130000&brandId=3048&brandDescription=MAYTAG&modelName=MAYTAG-DISHWASHER&diagramPageId=00001&componentDescription=CONTROL%20PANEL&documentId=M0509198&blt=06
Posted on Jul 18, 2010
SOURCE: Do you have parts for the west bend food processor
Mine is in good shape except for the chopping blade. I would be interested in that part from yours, if you can not find what you need.
Posted on Jan 09, 2011
  • 122 Answers
SOURCE: the silver plastic handle is
can u7pls resend the question
Posted on Jun 24, 2011
  • 63 Answers
SOURCE: the plastic connector that connects
year, make and model?
Posted on Aug 07, 2011
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
Tip
How to repair a broken door handle on a 1997 Buick Park Avenue.
You can find videos about removing the door panel and the exterior door handle on YouTube, so I will not cover those in this post. Other posts about this repair involve things like drilling a hole and inserting a bolt into the broken plastic handle, but if the breakage is in the area where these photos show, those fixes can fail in time. This fix reinforces and improves the faulty design of the part; in other words, auto makers (including BMW!) use plastics where metal, such as light-weight aluminum, should have been used. INSTRUCTIONS: 1. Remove the interior door panel. 2. Peel back the plastic covering from the door to access the door's interior cavity. 3. Remove the 2 10mm bolts on either side of the handle securing the door handle to the body. I recommend a ratchet wrench for the easier-to-reach nut and a socket for the other. 4. From the outside, pull the door handle out enough to reach the lock and opener rods from the plastic connectors on the handle so you can remove the handle from the door. 5. Remove the metal door opener arm from the handle. One bolt holds it in place. 6. Fashion a "splint" from a 1" X 1" piece of aluminum. It should be thin enough (about 2 or 3 millimeters thick) to wrap around the broken handle arm as shown in the attached photos. Be CAREFUL not to damage the other plastic handle components. In my photos, it appears a previous owner tried to repair the breakage with a thin bolt. You can see the dried, cloudy-colored glue beneath my aluminum splint. Be sure your splint is wrapped tightly around the broken arm so that the arm cannot come apart again. Good pliers are essential here to bend the aluminum splint as shown. 7. Once completed, reattach the metal opener arm to the handle and ensure the spring end rests in the notch of the arm. 8. Reattach the handle to the door body, ensuring the rods are back in their proper plastic "hooks". You cannot attach them incorrectly, as they only fit one way. Removing and reattaching the screws inside the door cavity can be tricky. The door frame edges are sharp. Be patient and careful not to cut yourself. It will probably take a good five minutes or more to get the screws back in place and tightened.
on Jul 06, 2015 | Vehicle Parts & Accessories
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
Oct 26, 2013 | Sanyo Microwave Ovens
Remove inside door handle driver side hyundai elantra 2001
probably not. most inside door handles are push on and held with a spring clip that requires a flat tool that slides between the handle and the plastic washer or the plastic plug in the center of the handle prises out and ther will be a small screw to remove then the handle slips off. Normally the screw has a 8 mm head or a philips screw recess
Jan 10, 2013 | Hyundai Motor 1999 Elantra
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
I can't open to fill tank.
Hehe, seem your spring pins is gone...
when you press the handle, normally it release the thank
and it is lift by a little plastic square attached to a spring...
it is probably broken...
push the handle and lift with a knife...
May 01, 2010 | iRobot 5800 Scooba Vacuum
The handle on my Maytag Quiet series 100
I had the same problem with my QS 100. I disconnected power first via the breaker then removed the 11 screws. I couldn't loosen the two electrical connections, but the door pulled far enough away to inspect the handle mechanism. The plastic handle fell out of whole handle assembly rather easily because two molded plastic pins protuding from either side had broken off and were loose inside. There was also a pair of molded plastic v-shaped forks right on the panel to hold the handle assembly and these were damaged but they just to seem to act as guides only (as the handle assembly is held in by two of the screws that were removed). Replacing the v-shaped forks would require a whole new door which I am NOT doing. It looks like I can a replacement handle in the same color with new pins (I am reading they may now be metal) for about ##15. Pretty easy to disassemble and inspect, only about 15 minutes.
May 29, 2009 | Maytag 24 in. MDB5600A Jetclean II...
32 people viewed this question
k24674
jasbo
jasbo
